Best flywheel clutch combo
Old Dec 24, 2001 | 09:47 AM
LuDeS's Avatar
New User
Default Best flywheel clutch combo
I have decided on the ACT extreme clutch kit... HA3-XTSS
But in terms of flywheel choices im not sure what to go with... Ive heard alot of positive & negatives with the various flywheels... What is the best flywheel to go with? I was looking into Fidanza what are some other good flywheels for 5th gen prelude?
Old Dec 24, 2001 | 10:23 AM
Greyout's Avatar
Default Re: Best flywheel clutch combo (LuDeS)
http://www.inlinefour.com for the JUN one... two different weights available.
Old Dec 24, 2001 | 07:33 PM
The Punisher's Avatar
Default Re: Best flywheel clutch combo (JDM LUDE)
I personally like the Clutchmasters flywheel. It uses a stock ring gear and has a replacable friction plate. There is a groupbuy going on at www.groupbuycenter.com right now. Cheaper than when I bought mine.
[Modified by gsr*lude, 9:40 PM 12/25/2001]
Old Dec 26, 2001 | 03:26 AM
vntperformance's Avatar
I would honestly go with the following, this is what I have!
Fidanza Flywheel & ACT HA3XTSS Clutch Kit
This kit is very streetable, and Grabs HARD, you'll be able to break 3rd gear!
vnt
Old Dec 26, 2001 | 11:36 AM
Greyout's Avatar
Default Re: Best flywheel clutch combo (vntperformance)
I don't think he is looking to break his transmission just yet.
j/k
Old Dec 27, 2001 | 10:04 AM
LuDeS's Avatar
New User
any other suggestions... btw how are those jun flywheels? the only reason i am staying away from the fidanza flywheel is because of how light it is 8lbs... I dont think a flywheel this light would work to well if i were to go FI... The jun fw weighs 12lbs which sounds more appealing for FI... Any suggestions/comments are welcome.
Old Dec 27, 2001 | 10:15 AM
JG Luder's Avatar
Unorthodox Racing. Aluminum Flywheel. They were 9lb's when I got mine, but they've up'd it to 10 now. Not a single moments complaint and nothing but good things from that company on any of my parts. (Flywheel and cam gears are on... pulleys aren't installed yet.)
Old Dec 28, 2001 | 11:31 AM
Red Wing's Avatar
Default Re: Best flywheel clutch combo (JG Luder)
I would go with an EXEDY clutch.I would do a search on flywheels though.Aluminum is light but how durable is it under extreme situations.Chrom-moly is a lot stronger.I know EXEDY does not make that application but does JUN or anybody make a Chrom-moly flywheel? I got a EXEDY Organic but did not replace my flywheel yet.Waiting to find a chrom-moly.
Old Dec 28, 2001 | 11:33 AM
JG Luder's Avatar
Default Re: Best flywheel clutch combo (Red Wing)
Mine has put up with more abuse than any of you could throw at one.
Old Dec 29, 2001 | 05:31 PM
1fastGSR's Avatar
New User
I've heard the JUN FW has starter problems on B series, don't know about H22, but might want to look into it.
Old Dec 29, 2001 | 10:33 PM
Default Re: Best flywheel clutch combo (1fastGSR)
Weither you are running FI or NA a light weight flywheel will help. Whatever flywheel you choose, make sure it uses a stock ring gear and has a replaceable friction plate. To me HP is money, and I don't know about you, but I don't have a tree that grows it. So, find a flywheel that meets the above and get the cheapest price for it. The weight thing can be summed up on way, less weight on the rotating mass, less HP used by the motor, for any application!
Oh yeah, I'm drunk!!!!!
[Modified by gsr*lude, 1:58 PM 12/30/2001]
Old Dec 30, 2001 | 06:54 PM
TypeRdude's Avatar
Default Re: Best flywheel clutch combo (gsr*lude)
http://www.diabloautosports.com/specials.php
We sell JUN and the Clutchmasters is on special.
Old Jan 6, 2002 | 09:10 AM
HybridSI's Avatar
Default Re: Best flywheel clutch combo (TypeRdude)
Sorry, but the EXEDY is the BEST unit on the market! Check out the HOTSHEET @ http://www.coximport.com As far as the REBUILDS go, ACT is the best, CM, CF, CN are the WORST. I have seen many problems with these units! All they do is take a new stock unit, build up the clamp load, paint/powercoat it, and ship it. They are pretty, but not safe under high rpms!
Old Jan 6, 2002 | 12:06 PM
Mike95lude's Avatar
Default Re: Best flywheel clutch combo (HybridSI)
Well if thats what they do then im sure ACT does the exact same thing. The only problems ive heard of about not handling high RPM'S is all ACT.
Old Jan 6, 2002 | 01:18 PM
F22PwrdS2k's Avatar
Well...I just bought an 8 pound fidanza flywheel and a 6 puck act with heavy duty pressure plate....it is being installed tomorrow so ill let you know
Old Jan 6, 2002 | 06:06 PM
HybridSI's Avatar
Default Re: Best flywheel clutch combo (SIPreludeRcr)
Sorry dude, May I suggest a shattershield You have a rebuilt stock unit, and an aluminum flywheel. Not to mention that 6 puck is going to beat up your driveline
Old Jan 7, 2002 | 11:21 AM
SilverLudeSi's Avatar
New User
SIPreludeRcr, what are you running where you need a solid 6 puck?
Old Jan 7, 2002 | 11:35 AM
JG Luder's Avatar
Default Re: Best flywheel clutch combo (SilverLudeSi)
I think he's stock. I warned him that daily driving will be a bitch.
Old Jan 8, 2002 | 07:17 PM
John's Avatar
New User
I finally got my car back yesterday; dropped in an ACT Xtreme PP w/ SS disc, Fidanza 8lber, and a Quaife LSD... and damn it grabs HARD! i must say that my left ankle is getting a work out, but i'll get used to it... unfortunately i won't be able to tell you what it can really do until i complete the break-in period (when i'll probably begin to break my axles)...
question: the Quaife LSD is definitely heavier than the OEM differential... so is the Quaife is going to increase the rotating mass? what i'm thinking is that i decreased the rotating mass on the flywheel, but increased the mass on the diff, so i'm pretty much back to where i'm started... is this true?
Old Jan 9, 2002 | 02:59 PM
Ludeaction's Avatar
Default Re: Best flywheel clutch combo (DunReit)
i need a new clutch and im gonna lighten my oem fly, how much is all this and install/?
Old Jan 9, 2002 | 08:53 PM
vwong's Avatar
Default Re: Best flywheel clutch combo (Ludeaction)
My suggestion from experience is Exedy Organic clutch and JUN lightweight (or ultra lightweight) flywheel. For the Exedy clutch, it's not re-built, it grabs real good, and the pressure plate isn't too stiff so the pedal feel is very similar to stock. And for the JUN flywheel, it's a chromoly flywheel, good quality, stronger than aluminum (aluminum flywheels tend to warp easier than chromoly). I've also heard about the starter problem on JUN flywheels, but Sun from Seattle told me that he didn't have to grind off the teeth as mentioned in the instructions from JUN, so did his friend's and they didn't experience any problem with their Preludes. I've also heard that someone with an Integra didn't grind off the teeth as well, and there's no problem.
j.orr
Mar 29, 2009 06:22 PM
PWRDbyHseries
Mar 26, 2007 06:19 PM
WVTURBOCRX
Jan 2, 2005 04:55 PM
b16a27
Nov 1, 2004 01:00 AM
