is it the clutch??????
okay, i have a 91 STD hatchback.
i swapped the z6 out of my 95 ex, since the EF is cable, I installed a 91 CRX SI tranny.
Ever since, everytime I'm at a complete stop and the wheels are turned all the way to either side, the car wont go.
Now its even worse since it wont go even if they are straight. My friend says its the cluth, what is it?? does anyone know??
Wassup Irving! (that's where I was born)
Has the car been able to run/drive at all? Did you look at the clutch when you did the swap? Could it have some grease or oil on it? It sounds strange with the whole ordeal about the wheels being turned. Other than the additional force required to move the car when the wheels are turned, it shouldn't really matter. It's not that much more, you would have noticed a severe performance difference at that point. When you actually drove it, did it seem like you could stomp the gas and the RPM would go up but the car didn't accelerate as much?
