poor mans type r
Old Nov 8, 2004 | 08:02 AM
bboylito's Avatar
Default poor mans type r
Short version:
should i get a complete 2000 civic si b16a2 swap and sell the block and then buy a gsr block and bolt it up to the b16 tranny and head and call it a day??????will this work????
Long Version:
hey i know i shouldnt get a 1.6 liter, i always wanted a gsr, but i can get a good deal on a 2000 b16 swap and i was wondering if in order to bild a poor mans type r if all i need to buy is the gsr block????
does everything in the gsr block bolt right up to the b16 tranny and b16 head and what not????
if i do this gsr block, with pr3 b16a2 head then what timing belt should i buy shouldnt it be for the block???
finally is this even a good idea does this setup pull harder then a gsr??? or should i pass up this GREAT deal and just save up for a gsr swap
Old Nov 8, 2004 | 08:03 AM
JDMallTHEway's Avatar
Default Re: poor mans type r (bboylito)
not again.
how much is teh b16a2 swap?
bboylito's Avatar
Default Re: poor mans type r (JDMallTHEway)
$1700
Old Nov 8, 2004 | 08:05 AM
bboylito's Avatar
sorry guys i have searched so i apoligize for the misunderstanding, i am not asking whether or not it works or if its possible
i am asking if i should or should not do this
yes i can make up my own mind but this will be my first swap and well i would rather listen to some of your experiances
Old Nov 8, 2004 | 08:09 AM
thats not too bad. Honestly, it sounds like alot of work for someone who is inexperienced.
personally, I would buy the si swap and put it in, and go from there
however, it will all bolt right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito &raquo;</TD></TR><TR><TD CLASS="quote">hey i know i shouldnt get a 1.6 liter,</TD></TR></TABLE>
Why not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito &raquo;</TD></TR><TR><TD CLASS="quote">finally is this even a good idea does this setup pull harder then a gsr??</TD></TR></TABLE>
I think it will. the b16/b18 hybrid seems to work well, and teh shorter gears of the si tranny will do you good.
Old Nov 8, 2004 | 08:12 AM
SiKid86's Avatar
just put the b16 in your really gonna go thu all that trouble for 10 hp? just take that 600 (price range of a b18c1 block) and apply it to a turbo setup.
Old Nov 8, 2004 | 08:16 AM
bboylito's Avatar
Default Re: poor mans type r (SiKid86)
well i am not just going to buy a gsr block and thats it i will sell my b16a2 block and add whatever the difference is my only fear is that i wont be able to find a gsr block in good condition that hasn't been beaten
if i just swap the b16 then i will go turbo, but if i swap the gsr block i will go NA
i'd rather go Na for reliability issues but with the b16 its worth going turbo so that i can get some kind of power out of the biatch
Old Nov 8, 2004 | 08:17 AM
bboylito's Avatar
before vtec crossover a b16 is the same as my d16
Old Nov 8, 2004 | 08:21 AM
snatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito &raquo;</TD></TR><TR><TD CLASS="quote">before vtec crossover a b16 is the same as my d16 </TD></TR></TABLE>
Before the end of 3rd gear I have 1-2 cars on my friends' b16's in my d16...
edit: not trying to start a b-series -vs- d-series war
trooper0641's Avatar
....keep your d16 and turbo it you'll make more power than that poor man's type r.
Old Nov 8, 2004 | 09:06 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: poor mans type r (trooper0641)
I basically just did that, not because I wanted to but because I had to lol.
Originally I had a SirII B16 Swap with LSD trans, but i crashed the car and needed a new transmission so i got a JDM ITR trans. (4.40 not 4.785, i know i know..) and put that into my new civic. Then I spun a bearing. (ALWAYS CHECK YOUR OIL!!) so I picked up a B18C5 shortblock, some ITR cams, Intake Manifold and Throttlebody, so now, I have basically a Type R, without the headwork.
Old Nov 8, 2004 | 10:15 AM
bboylito's Avatar
Default Re: poor mans type r (JDM_Ej)
jdm ej how does the car run??????????
kaneboi
Aug 1, 2010 01:49 PM
jkalex05
Aug 31, 2009 10:15 PM
Sivic87
Feb 11, 2006 06:06 PM
Sivic87
Dec 25, 2005 07:33 PM
redboost10
Feb 13, 2004 12:25 AM
