trunk release switch removel??
Old Nov 8, 2004 | 07:45 AM
spicoli's Avatar
Default trunk release switch removel??
How do i discontect this, where would the cable be to disconect it?
Stereo just got lifted so i want to beable to keep my trunk locked, without someone being able to hit that switch by my foot and open the trunk,
Old Nov 8, 2004 | 07:54 AM
JDMallTHEway's Avatar
Default Re: trunk release switch removel?? (spicoli)
open your trunk.
theres a steel cable that connects to your trunk latch, just disconnect it.
Old Nov 8, 2004 | 07:55 AM
lohatch's Avatar
you should be able to take the plastic cover off that wraps around that lever and then you should be able to see the cable. you will just need to remove the cable from the lever. you can also do this on the other end of the cable which would be located in your trunk lid.
Old Nov 8, 2004 | 07:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spicoli &raquo;</TD></TR><TR><TD CLASS="quote">How do i discontect this, where would the cable be to disconect it?
Stereo just got lifted so i want to beable to keep my trunk locked, without someone being able to hit that switch by my foot and open the trunk, </TD></TR></TABLE>
don't you have the key lock?? where you can turn your key and lock the trunk switch, so it wont open the trunk?
Old Nov 8, 2004 | 08:12 AM
spicoli's Avatar
Default Re: trunk release switch removel?? (JDMallTHEway)
ya but for some reason the key dont work, so i figure that just disconecting it is easier and safer, from theives that is
But it's in the trunk, if i want to disconect it what do i do?
Just pull the cable off? cut it?,
Little nervous with the car, it was my first time being robbed, and i want it to be the last
Old Nov 8, 2004 | 08:26 AM
delsolian's Avatar
Default How to install trunk release?
hey i got a 94 del sol.. that doesn't have trunk release ..
my question is. that is there a such thing called a "trunk release kit"
because its a hassel getting out and popping the trunk every time..
thanks in advance
Old Nov 8, 2004 | 08:33 AM
you should be able to loosen a screw and slip the cable off, be careful, cause its very easy to make it so the latch wont close...I know from experience.
Old Nov 8, 2004 | 08:34 AM
Default Re: How to install trunk release? (delsolian)
yes and no, I'm not too sure but
1. go to an alarm place and see if you can get the remote trunk popper, tahts your best bet.
2. get your own thread.
Old Nov 8, 2004 | 10:55 AM
spicoli's Avatar
Default Re: How to install trunk release? (JDMallTHEway)
can i just cut it?, i guess that's a final decision?
dont wanna *** up the latch
Old Nov 8, 2004 | 11:02 AM
Default Re: How to install trunk release? (spicoli)
you can cut it, but if you ever want it back, your gonna have to buy a new one from honda, and put it in, or have it put in.
loopyjuju
Jan 2, 2012 03:04 PM
CRXizSLAMM'd
Nov 9, 2004 01:28 PM
Dan GSR
Feb 21, 2003 07:16 AM
kefka
Jan 5, 2003 01:14 PM
madhatter
Dec 7, 2001 12:52 PM
