Code 76 1999 Accord lx 4cylinder
Old Nov 8, 2004 | 07:16 AM
1990hondaHF's Avatar
Default Code 76 1999 Accord lx 4cylinder
I did a search and all I found is one post saying it is a V6 error code....I have a 4 not a 6....I checked the code three times just to make sure I'm not crazy.....anyway, here is the symptom.....the car accelerates fine, no misfires, the problem happens AFTER I go through the gears and take it out of gear.....the idle drops way too low. after anywhere between 5 seconds and say 30 seconds the idle goes back to normal. If I reset the ECU the problem goes away....for a while. It doesn't seem to be affected if the car is hot or cold, it still throws the code. Any ideas?
just found a code list that had "....or random misfire" by code 76....ah here we go
RickP
Nov 2, 2013 10:22 PM
sammybananas
Feb 19, 2013 07:27 PM
BaLListic_Evo
May 2, 2008 07:15 AM
crxY-49
Jul 1, 2004 06:26 PM
