Well, it stayed together and gained 2 seconds at the track.
Old Nov 8, 2004 | 06:43 AM
Driven's Avatar
Default Well, it stayed together and gained 2 seconds at the track.
Was worried the engine might have a blown head gasket after some smoking issues... yet, i was unable to get it to smoke since the catch can install... odd.
I am losing coolant though, but, I have a hose that looks like it's leaking on the exhaust...which would cause the smoking...who knows.
Regardless, I took it to the track today. NASA was running LVMS's ORC. I love this track since there's a lot of higher speed turns as well as lots of passing room.
Last time out, i netted 2:09s pretty consistently...that's with 36lb 15" wheels/tyres and a B16A w/ 134whp.
This time out, i had 32lb 15" wheels/tyres (same tyres) and a b18c1 w/ 158whp.
1st Session, 2:11s. Not a problem as I know ***I*** had more.
2nd Session, 2:09s. A bit better, but, I can break later at certain areas.
3rd Session, 2:07s. Much better and I almost felt like I was drifting the car thru more turns.
4th Session, 2:08s, but I ran out of gas on lap 3. Do'h.
During my 2nd session, I was running with a '90 Civic Si w/ a B18C5 in it on Toyo RA1s (i was on Victoracers v700s). We were ALL over each other. He would pull away at the long straights (but, not by much)... I would catch up with him in some of the turns. I had a lighter car (CRXs ARE better than Civics ), but he had a LSD.
Biggest thing was, he could brake MUCH (10-15') later. Although he was locking them up in a lot of turns... it was still noticably later. He's running the same brake setup as I was, except he had rear discs and newer pads (my pads were at the backing plate by the end of the 4th session).
Overall, the extra 20+hp and nearly 20ft-lbs of torque lowered my lap times by 2 seconds.
I had a friggin BLAST running with another car similarly prepped to mine. It's a very surreal experience running with someone who can drive their car as well as you can drive yours and have equal power to weight ratio...
Old Nov 8, 2004 | 06:53 AM
drdisco69's Avatar
Default Re: Well, it stayed together and gained 2 seconds at the track. (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">It's a very surreal experience running with someone who can drive their car as well as you can drive yours and have equal power to weight ratio... </TD></TR></TABLE>
That is about the most fun you'll ever have. to you for a great time out. What alignment are you using? Suspension, etc?
Old Nov 8, 2004 | 07:33 AM
spettinger's Avatar
Default Re: Well, it stayed together and gained 2 seconds at the track. (drdisco69)
right on, i take it the B18c has gone in since the grm layout?
Old Nov 8, 2004 | 08:14 AM
drdisco69's Avatar
Default Re: Well, it stayed together and gained 2 seconds at the track. (91hatchattack)
Upon further inspection, your website answered most of my questions. Still curious about the alignment, unless it's a secret.
Old Nov 8, 2004 | 11:55 AM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
driven- if your coolant hoses are feeling very firm and pressurized, or your oil level seems to be increasing (or decreasing) rapidly, you probably do have a leaking headgasket.
Old Nov 8, 2004 | 02:20 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
wow the ***** challenge looks pretty fun!
Driven ur car is a beast, i watched the ***** video for u brotha
Old Nov 8, 2004 | 02:40 PM
Rywire's Avatar
Default Re: Well, it stayed together and gained 2 seconds at the track. (b2o-vtec)
Very cool Vid Kam, I dug it!! (jdm uber sweetness)
Ryan
Old Nov 8, 2004 | 04:53 PM
Driven's Avatar
Default Re: (mike_belben@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">driven- if your coolant hoses are feeling very firm and pressurized, or your oil level seems to be increasing (or decreasing) rapidly, you probably do have a leaking headgasket. </TD></TR></TABLE>
the oil pressure stays steady except at various RPMs (which it should move).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Upon further inspection, your website answered most of my questions. Still curious about the alignment, unless it's a secret. </TD></TR></TABLE>
I'm running 1/16" toe-out in the front and 1/16" toe-in in the rears. I totally stole my alignment from a GRM article...
and thanks for the kind words all... yes, the B18C1 went it after the article. Took a month, but, it runs good now. After this past weekend, I have a feeling i may just have a leaking coolant hose and no blown hg...
Old Nov 8, 2004 | 10:27 PM
TAG's Avatar
TAG
Default Re: Well, it stayed together and gained 2 seconds at the track. (droppedcrxsi)
Nice video Zam &lt;grin, see credits&gt;
Very nice to see a CRX represent out there. I've always been a fan of your yellow racer
Btw, is there a version of this video without the background music?
I would love to hear the engines and tires
thanks
junbb1
May 3, 2006 09:35 PM
junbb1
Apr 30, 2006 06:02 PM
2camsaam
Oct 19, 2003 12:56 AM
DMF
Feb 26, 2003 11:28 AM
MattD@Stoptech
Sep 7, 2001 05:39 AM
