H22 tranny fluid, how much and what kind?????
Old Nov 8, 2004 | 04:29 AM
enigma94's Avatar
Default H22 tranny fluid, how much and what kind?????
I know this has probably been cover a lot before but the search function isnt working (atleast for me).
So how much does it hold, and what is the BEST fluid to run. I dont really care too much about price.
Old Nov 8, 2004 | 06:33 AM
SuperSlow's Avatar
Default Re: H22 tranny fluid, how much and what kind????? (enigma94)
Honda MTF. 2.1 quarts.
I will be going back to it from synchromesh.
Old Nov 8, 2004 | 11:53 AM
enigma94's Avatar
Default Re: H22 tranny fluid, how much and what kind????? (SuperSlow)
Anything i can pick up from autozone or should it be factory honda? I know they run a little lower weight (atleast for oil) than i like to run(they suggest 5w30 and i run 10w40) so is this the case with the tranny fluid too?
Old Nov 8, 2004 | 12:25 PM
Paul H22A4's Avatar
You get it from Honda
Old Nov 11, 2004 | 03:18 AM
littledan's Avatar
i'm running syncromesh in my 95srv and i love it. had minor 3rd gear and 5th grind and now it's gone... only $9 cdn a liter too
Old Nov 28, 2004 | 12:20 AM
. o 69 o .'s Avatar
Default Re: (littledan)
do you do a complete fill with syncromesh or is it a blend?
Old Nov 28, 2004 | 01:59 AM
littledan's Avatar
i used all syncromesh...
Old Nov 28, 2004 | 05:43 AM
specialedition's Avatar
I used synchromesh but I know after using it for 6000 miles it is waaaay too thin for a honda transmission .... I pulled quite a bit of metal shavings outta it with my spoon drain bolt. I believe the excessive syncro wear is not worth the no syncro grind ..
Honda MTF is 10w40 oil and I have switch to somthing called BG synchroshift 2 lower syncrowear and no ghostly shifting or grinding feel It is the best I have used so far and I can get the stuff at a deal --- the honda trannys use 2 quarts fill it till it over flows the fill hole a little then you are good --
BG Syncroshift 2 is the sheat
http://www.bgprod.com/bgprofes....html
Old Nov 28, 2004 | 06:29 AM
eMpAtHy's Avatar
Default Re: (specialedition)
most people here will tell you honda MTF. i bought it for like 6 dollars a bottle at a local honda dealership. i will being doing a fluid change really soon to honda mtf. i bought 3 bottles just in case..
Old Nov 28, 2004 | 07:09 AM
digitalh3lix's Avatar
Default Re: (eMpAtHy)
i heard redline tranny oil was really good.. my friend has it in his car.. but im not sure on that one.
Old Nov 28, 2004 | 09:00 AM
DarkBB4's Avatar
Default Re: (digitalh3lix)
just bought syncro mesh..
just a quick question
which side is the little Filler/Flusher on?
passenger or driver?
Old Nov 28, 2004 | 10:42 AM
. o 69 o .'s Avatar
Default Re: (DarkspeedVtec95)
passenger side... i just finished doing mine
i used 500ml or 80w90 and the rest 10w30
guess its time to see what happens
Old Nov 28, 2004 | 02:33 PM
. o 69 o .'s Avatar
Default Re: (B16B)
all my bearing noise is gone, but now i have a very slight scratching on second gear. guess i can lie with that .... Is it typical to have a bit of a scratch immediately after a fluid change?
Old Nov 28, 2004 | 04:38 PM
GOTNOS's Avatar
Default Re: (B16B)
i use generic dextron 3 automatic transmision fluid and have been for 1 year and my car shifts perfect.
Dgr8one21
Apr 21, 2008 08:14 PM
krazycivic4u
Jun 3, 2006 08:18 PM
P1mpSlap
Mar 15, 2003 03:28 PM
Nameless RB26
Jan 23, 2003 08:24 PM
Money Hou$e
Apr 24, 2002 04:46 PM
