piping bend
Old Nov 8, 2004 | 03:49 AM
RACEPAK's Avatar
Default piping bend
hello everybody
i'v always wonderd if there is any intrument or a diy gadget to bend charge pipes at home?
best regards moshik galimidi
Old Nov 8, 2004 | 07:48 AM
Doctor CorteZ's Avatar
Default Re: piping bend (RACEPAK)
make jigs out of conduit or something cheap and use those as a template.
Old Nov 9, 2004 | 05:47 PM
shauniewalnuts's Avatar
Default Re: piping bend (Doctor CorteZ)
ttt
Old Nov 10, 2004 | 07:04 AM
RACEPAK's Avatar
Default Re: piping bend (shaun311)
any diy's ?
Old Nov 10, 2004 | 08:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">any diy's ?</TD></TR></TABLE>
I told you already.
make templates and bend pipe.
Old Nov 10, 2004 | 08:08 AM
nonsense's Avatar
http://jd2.com/
Old Nov 10, 2004 | 10:01 AM
blackwagon's Avatar
Default Re: piping bend (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">http://jd2.com/ </TD></TR></TABLE>
you can't bend a charge pipe with those... unless your going to make it from some thick *** tubing...
Old Nov 10, 2004 | 11:09 AM
Default Re: piping bend (blackwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackwagon &raquo;</TD></TR><TR><TD CLASS="quote">
you can't bend a charge pipe with those... unless your going to make it from some thick *** tubing...</TD></TR></TABLE>
thick diam ? or thick wall ?
I see no reason , other than overkill , that those wouldnt work fine for this application.
Old Nov 10, 2004 | 01:04 PM
juicedse's Avatar
Default Harbor freight is your friend
Mine atleast
http://www.harborfreight.com/c...44094
Or for the professional
http://www.harborfreight.com/c...47189
Old Nov 10, 2004 | 01:41 PM
RACEPAK's Avatar
Default Re: Harbor freight is your friend (juicedse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicedse &raquo;</TD></TR><TR><TD CLASS="quote">Mine atleast
ohh man thats great i'm gonna order one of these right now....
can i bend ss and aluminium with this?
Old Nov 10, 2004 | 01:43 PM
nonsense's Avatar
Default Re: Harbor freight is your friend (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">ohh man thats great i'm gonna order one of these right now....
as long as your charge pipes are less than 2"
why not just buy pre-mandrel bent pipes?
Old Nov 11, 2004 | 04:16 AM
RACEPAK's Avatar
Default Re: Harbor freight is your friend (nonsense)
dang i i was sure its good for 5/8"-3"
anyway i found this:
http://www.harborfreight.com/c...35336
any pros and cons ??
Old Nov 11, 2004 | 09:25 AM
b16hybridsol's Avatar
i think all those are pressure bent as in the diameter of the piping gets smaler where the bend is with those. I'd like to try to find a manual mandrel bender but no luck so far
Old Nov 11, 2004 | 09:40 AM
mattjohnston's Avatar
Default Re: Harbor freight is your friend (b16hybridsol)
Mandrel benders are $$$$$$$$$$
Old Nov 11, 2004 | 09:46 AM
89civicdx's Avatar
any pros and cons ??</TD></TR></TABLE>
yeah they suck
they crimp the pipe , the dies are ****, I'd give you mine if you lived near me.
Old Nov 11, 2004 | 12:08 PM
Default Re: Harbor freight is your friend (mattjohnston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattjohnston &raquo;</TD></TR><TR><TD CLASS="quote">Mandrel benders are $$$$$$$$$$</TD></TR></TABLE>
i was talking about manual not hydrolic, extreme price difference
Old Nov 11, 2004 | 03:18 PM
AROD's Avatar
http://www.harborfreight.com/c...47189</TD></TR></TABLE>
do these crimp the pipe , or are they mandrel bends?
Old Nov 12, 2004 | 07:24 AM
nonsense's Avatar
Default Re: Harbor freight is your friend (1.83Tc)
The only way to get true mandrel bends is with a mandrel bender. You have to have a mandrel that goes inside the pipe to keep it from getting crushed when bending. It's pretty much bent from the inside.
oh, and they're not cheap
http://www.ercolina-usa.com/mandrel-bender.htm
http://www.hinesbending.com/
http://www.advancedfab.com/transfluid/K-specs.htm
Old Nov 12, 2004 | 02:27 PM
Optiks.'s Avatar
my pops said back in the day he would have asimilar tool to the JD squared bender but would pack the tubing full of sand and cap it off with some tapered woulden plugs, heat it with an oxy torch and then bend it, the sand would not allow for the tubing to get smaller achieveing mandrel bends
Old Nov 13, 2004 | 03:51 PM
RCautoworks's Avatar
Try this maybe
Old Nov 13, 2004 | 07:27 PM
90DALS's Avatar
i have that orange bender, and i have the other HF pipe bender.
the orange one crushes pipes bad. i tried 2.5" pipe and it just crushes it.
i have the other pipe bender (2.5" doesnt fit in it) but i havent tried bending anything with it yet
teg racer 877
Mar 4, 2006 07:52 PM
b18ccivics
Welding / Fabrication
13
Jun 15, 2005 06:48 AM
C-West Civic
Jan 31, 2005 04:20 PM
boostedsi1
Aug 6, 2003 09:06 AM
InTeGrA B18b1
May 2, 2003 12:15 PM
