left front suspension problems....
Old Nov 7, 2004 | 11:14 PM
ATS*Mark's Avatar
OG triple OG
Default left front suspension problems....
when my car is off and on . but not moving . when i turn the wheel to the left or right i can hear a clunking noise like somthingse loose . and also a creeking noise like one of my poly mounts is dry or somthing . my question is , where to start looking? what could be the causes of his . setup is tein flex's and skunk2 camber kit . let me know where to start looking. thanks!
Old Nov 7, 2004 | 11:22 PM
black cx's Avatar
Default Re: left front suspension problems.... (OnePointSicks)
Im guessing its the axle. Same thing happned to me when i had my d series, but when i swapped in my b series, the noise was gone
Old Nov 7, 2004 | 11:28 PM
ATS*Mark's Avatar
OG triple OG
Default Re: left front suspension problems.... (black cx)
so your thinkin the axle....i need to replace them anyway ill try that.
Old Nov 8, 2004 | 12:07 AM
=GAME='s Avatar
did it always make these noises or just recently? did you mess with the suspension or with the car lately?
Old Nov 8, 2004 | 12:29 AM
Quad-Damag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnePointSicks &raquo;</TD></TR><TR><TD CLASS="quote">so your thinkin the axle....i need to replace them anyway ill try that.</TD></TR></TABLE>
ya the clicking noise is a broken, axle, but ur car is slow, i don't know how u broke it. hahaha jk
go with some gator stage 2 for ur new setup
it should own nicely
Turbo 1.6 Liter SOHC VTEC
Im scarddd
Old Nov 8, 2004 | 12:44 AM
ATS*Mark's Avatar
OG triple OG
Default Re: left front suspension problems.... (Quad-Damge)
i havent messed with the suspension reciently at all...and its not clicking . and it doesnt do it around turns.
Old Nov 8, 2004 | 01:01 AM
ATS*Mark's Avatar
OG triple OG
any other possibilities?
it sounds like the left front creeks when i hit bumps too.
Old Nov 8, 2004 | 01:37 AM
slammed_93_hatch's Avatar
could be somthing in your steering rack
Old Nov 8, 2004 | 12:31 PM
ATS*Mark's Avatar
OG triple OG
Default Re: left front suspension problems.... (slammed_93_hatch)
what in my steering rack would do that?
Old Nov 8, 2004 | 01:00 PM
errr i dunno but for it to do it when your stoped id think its somthing in there.
Old Nov 8, 2004 | 01:19 PM
Slopoke's Avatar
Have you tried jacking the front end up off the ground and then turning the wheel?
Old Nov 8, 2004 | 01:21 PM
ATS*Mark's Avatar
OG triple OG
Default Re: left front suspension problems.... (Slopoke)
no i havent , what should i look for when i do it?
Old Nov 8, 2004 | 01:35 PM
Slopoke's Avatar
Just thinkin you might be able to get under there, have someone else turn the wheel, and you can maybe see where the clunking is coming from.
I'd check out your upper and lower ball joints, outer tie rod end, and while the car is jacked up, see if there is any play in your wheel bearing.
Old Nov 8, 2004 | 01:42 PM
ATS*Mark's Avatar
OG triple OG
how to i check for play in the wheel bearings? i know to check for the ball joints.....
Old Nov 8, 2004 | 01:43 PM
grab the wheel, on oppisite side then push forward and back to see if it moved at all
Old Nov 8, 2004 | 01:50 PM
ATS*Mark's Avatar
OG triple OG
push it foreward twards the front bumper or pull it twards me?
Old Nov 8, 2004 | 01:53 PM
civiccpedx's Avatar
i would say check the cv joint, or the lower control arms. my control arm bushings are bad and mine makes a ratteling noise when i go over bumps.
crxsleeper210
May 22, 2020 02:46 PM
GagnarTheUnruly
Jul 26, 2011 02:51 PM
Glock17
May 13, 2011 02:22 AM
littleblue
13
Jul 27, 2006 09:15 PM
LegendLS95
Aug 12, 2001 06:16 PM
