how too determine the shade of the glass?
Old Nov 7, 2004 | 06:23 PM
GOLDBERG's Avatar
Default how too determine the shade of the glass?
i was wondering how i determine the shade of the glass or plastic whatever on the helmet...some helmets around the shop are REALLY dark..too dark for me...really hard too see..however my other friends helmet isnt as dark and i can weld with it pretty good..i was wondering how i can determine the shade of the glass so that when i buy my own helmet it will be the lightness/darkness that i want n need.thanks alot
Old Nov 7, 2004 | 08:04 PM
L-CON1's Avatar
Default Re: how too determine the shade of the glass? (GOLDBERG)
when you buy your helmet use shade 10 for mig and 11 for tig! if you want you can use 11 for both. unless you buy an auto darkening then you can adjust to these settings..
Old Nov 7, 2004 | 08:30 PM
ExploitedRacing-HR's Avatar
"when you buy your helmet use shade 10 for mig and 11 for tig! if you want you can use 11 for both. unless you buy an auto darkening then you can adjust to these settings.."
Not true.. i use as low as 9 for tig welding. I use an autodarkening and 9 comes in handy when doing fine welds
Old Nov 7, 2004 | 11:34 PM
mxnut's Avatar
Default Re: (ExploitedRacing)
If you are going to use plastic you will have to use a clear glass lens in front of the plastic ,I would just get glass lens. For tig try an 8 or 9 for sheet metal,10,11,12 for stick, mig I don't know.
Old Nov 8, 2004 | 05:52 AM
bigTom's Avatar
Default Re: (mxnut)
i use 9 for all mig and most tig... dc up to around 120a and but in ac generally anything over 80 i use either 10 or 11... for plasma cutting i have a setting which is alot less called torch... it just darkens it enough not to hurt ur eyes
Old Nov 8, 2004 | 06:51 AM
GOLDBERG's Avatar
Default Re: (ek9t)
so nobody knows how too determine your shade ?
Old Nov 8, 2004 | 10:26 AM
Doctor CorteZ's Avatar
Default Re: (GOLDBERG)
not unless you know the helmet brand/model.
Old Nov 8, 2004 | 01:42 PM
JunY's Avatar
Default Re: (Doctor CorteZ)
Minimum Shade for Oxyfuel cut or oxyfuel welding is shaded 5 lens. If your eye's are sensitive, go on shade lens up.
Minimum for Shade for ARC, MIG, or TIG is shade 10 lens. At this lens level it could be varied by what kind of gas is used. Shaded 10 lens is the least level lens you should be using orelse your looking into ultra violent light. If you are in a closed dark inviroment welding TIG, preferred lens shade is between 12~14.
Old Nov 9, 2004 | 04:20 PM
CaseMX220's Avatar
Default Re: (JunY)
I use a number 9 for everything welding... O/A cutting i dont use a shade and i can see perfectly.... Now where did i leave that magnifying glass again.....
Old Dec 3, 2004 | 09:55 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">not unless you know the helmet brand/model.</TD></TR></TABLE>
I just bought this helmet
http://www.harborfreight.com/c...91212
So what shade would be best for mig ?
There are also sensitivity settings, high or low, which one would be better. I'm guessing high
Also for delay time, there is fast and slow ?
Old Dec 3, 2004 | 01:52 PM
jdmek910's Avatar
go with an auto darkening eye peice ... you'll love it
Old Dec 3, 2004 | 01:59 PM
jdmek910's Avatar
Default Re: how too determine the shade of the glass? (jdmek910)
GOLDBERG : so nobody knows how too determine your shade ?
some of the newer lenses have it etched in to them but you would have to remove the glass to see ... if it is older ... most likely the only way to tell is comparison or a color guide that that manufacturer supplies... but listen if it is that old that you dont even know the shade why not just replace it ???
Old Dec 3, 2004 | 04:40 PM
My book says 10 I think, I tried using 9 but it seemed like after a while I started to see white blobs.
Old Dec 3, 2004 | 05:10 PM
Bailhatch's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
So what shade would be best for mig ?</TD></TR></TABLE>
I use one of those HF cheapies. My helmet is shaped a little different but the lens and **** look identical as does the price. I set mine on fast and high. I keep the darkness at 13 and have no problems seeing when I'm MIGing thick stuff. One warning with an autodarkening setup, A couple times I have been flashed because even thought my eyes were able to see the arc the sensors were just out of line so it didn't switch over. Otherwise I have used it for about 30lbs of .023 wire and it still works great. Replacing/cleaning the plastic shield every day sucks though. This is what my welds look like.&gt;
Old Dec 3, 2004 | 05:24 PM
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
[/img]</TD></TR></TABLE>
Nice welds. Yeah I know what your talking about, a lot of people say if the sensor is not in the right spot it won't catch it. My mask is pretty sensitive though, if you flick a lighter by the glass it will auto darken right away. Really make it so much easier to weld.
Old Dec 4, 2004 | 08:40 PM
Engloid's Avatar
OG Fabricator
Are you pumping the button on and off? It looks like it.
Old Dec 5, 2004 | 06:43 AM
Agtronic's Avatar
There is no science or law to chosing the correct shade. Basically, when it's too bright, move up a shade. If you see spots after a bead, you need to move up a shade. When I MIG weld 3/8" steel plate @ 27 volts, I use a #12 shade, if I weld at 34v, I'll use a 13 or even a 14. That ish gets bright!
For 16G steel piping with the TIG, I use a #10 shade.
averyvm
Engine Management and Tuning
Aug 12, 2008 02:33 PM
bmoua
Oct 4, 2007 12:14 PM
idriveadelsol7
Apr 16, 2005 01:16 PM
nEoMuGen
Nov 6, 2002 05:55 PM
slvrcivic97
Nov 2, 2002 07:51 AM
