h22a swap question
just for the record i tried to search this question but the server is down so i couldn't get an answer.
i plan on swapping my 5th gen but i don't want to buy more than i need and i want to make sure i have everything when i start i have found a couple sites that have a few different kits (and if someone knows a good site i should look at that would be appreciated) but im not sure which is better so if you could help me out that would be awsome.
kit one
2.2 Liter DOHC VTEC Engine hydro operated tranny 200hp/161tq/10.6 Compression Ratio. Motor Swap incls Tranny, ECU, half shaft, stock shift linkage, stock motor mounts, alternator, starter, clutch, flywheel, intake manifold, exhaust manifold, fuel rail, injectors, distributor, engine harness. Motors average 35,000 miles and come with a 100% start up warranty. LSD Trannys Avail ADD $250. *
kit two
- Motor
- Hydraulic Tranny
- ECU (P13)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
or kit three
- Motor
- Hydraulic Tranny
- ECU (P13)
- Axles with Half Shaft
- Shifter Cables
- Shifter Assembly
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
kit one
kit two
- Motor
- Hydraulic Tranny
- ECU (P13)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
or kit three
- Motor
- Hydraulic Tranny
- ECU (P13)
- Shifter Cables
- Shifter Assembly
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Ok buddy - I'll bite and give you a few pointers as I have a swapped '94 Accord w/ JDM H22A.
- You will use your shift linkage from the Accord as it is compatible
- You will use your axles as they are the correct length (prelude ones are a little longer)
- You can use your existing motor mounts except for the driverside - that one needs to be a prelude mount with a little grinding done to it.
- You will need a little exhasut work as the exhaust manifold downpipe from the prelude is different from the Accord's - 2 holes v. 3 holes. You will need to weld on the correct flange to mate up with the rest of your exhaust.
- You will need to decide if power steering is a must have as this will take some work to make the accord lines line up with the prelude pump.
- You will need to add some additional wires. If your Accord is an Ex trim - all you need to add is the knock sensor wire. If LX/DX trim - you will need Vtec pressure switch wire, knock sensor, and Vtec solenoid wire.
While you are at, before dropping in the motor, replace the following parts
Timing belt/balancer shaft belt
Water pump
clutch and pressure plate
resurface flywheel
new spark plugs and wires
New cap and rotor (if JDM motor - buy a '92-'95 Civic DX cap = internal coil)
Replace upper and lower radiator hoses - might as well put out for a new thermostat as well.
you will need new accessory belts (alternator/ac/power steering - but this depends on what brackets you use as well as if you use the accord or prelude alt. or compressor)
If I have forgotten anything - I'm sure some other members will jump in with their info.
GOOD LUCK!!
Water pump
resurface flywheel
GOOD LUCK!!
Jerry31
Jul 4, 2004 11:32 AM
