Front Oem bumper Ebay?
Old Nov 7, 2004 | 10:37 AM
BadEH2's Avatar
Default Front Oem bumper Ebay?
would this bumper be very very bad quality? or bout the same, cuz i recently sanded my bumper Wrong, i used 40 grit paper, n now its all FUZZY AN DISGUSTING... i htnk i would need a new bumper... all cuz of me n my friend rushing..
http://cgi.ebay.com/ebaymotors...33640
Old Nov 7, 2004 | 10:40 AM
Bone Stock's Avatar
From: City of fakeJDMs but their vT3s HiT H3ll4 L0uD...., usa
Default Re: Front Oem bumper Ebay? (BadEH2)
don't think so, why don't you just go to your local junk yard see if they have one there or search H-T.
DC4KiD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BadEH2 &raquo;</TD></TR><TR><TD CLASS="quote">would this bumper be very very bad quality? or bout the same, cuz i recently sanded my bumper Wrong, i used 40 grit paper, n now its all FUZZY AN DISGUSTING... i htnk i would need a new bumper... all cuz of me n my friend rushing..
http://cgi.ebay.com/ebaymotors...33640</TD></TR></TABLE>Just use some body-filler or bondo to smooth out the messed up parts.
Old Nov 7, 2004 | 10:46 AM
BadEH2's Avatar
Default Re: Front Oem bumper Ebay? (DC4KiD)
dude, where do i get BODY FILLER? if i use bondo.. wouldnt it look all uneven nshit?
Old Nov 7, 2004 | 10:52 AM
TRD MA70's Avatar
bondo is the brand name of one type of body filler, body filler = bondo
Old Nov 7, 2004 | 10:53 AM
BadEH2's Avatar
Default Re: Front Oem bumper Ebay? (TRD MA70)
ic, but what about the bumper on EBAY, does that seem liek a bad bumper or wat?
Old Nov 7, 2004 | 11:03 AM
Del Sizzle's Avatar
Don't buy the ebay bumper, and the reason why is because this person doesn't have any type of feedback. It is generally not a good rule to buy from someone like that. He/She could very well take your money. Your bumper should be fine. Go over it with a finer grade of sand paper. Start with a 120 and work your way up.
Old Nov 7, 2004 | 11:05 AM
DC4KiD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BadEH2 &raquo;</TD></TR><TR><TD CLASS="quote">dude, where do i get BODY FILLER? if i use bondo.. wouldnt it look all uneven nshit?</TD></TR></TABLE>lol, thats why ppl sand it down.
Old Nov 7, 2004 | 12:21 PM
BadEH2's Avatar
GOOOD IDEAAA!! lol im such a retard neway, so i can just put a layer of bondo and then after it drys i can just sand it with VERY HIGH grade of sand paper right?? maybe like a 800 ?
Old Nov 7, 2004 | 12:30 PM
erikiksaz1's Avatar
Why don't you start sanding with higher grits?
Old Nov 7, 2004 | 12:38 PM
5STAR3's Avatar
Default Re: Front Oem bumper Ebay? (erikiksaz1)
$135 shipped
Old Nov 7, 2004 | 01:45 PM
Mr HYDE's Avatar
Default Re: Front Oem bumper Ebay? (envision2teg)
i wouldnt use body filler on a bumper, thay have **** thats for plastic, u put body filler/bondo on it will crack the bumpers flex and bondo dont flex as much and will crack, but they make **** for plasitc i even think its plastic bondo not entirly sure but i seen bondo crack more then once on bumpers
Old Nov 7, 2004 | 01:51 PM
quick_DC5's Avatar
Do what ever you want. Its your choice. Its obvious you have no clue anyway, since look at what you did. If it was my choice, I would look at the condition of my bumper to see if is worth repairing. If you are just trying to fix the 40 grit scratches, I dont think you need to use body filler. Why did you sand it in the first place? To repair damage to it? Remember, an aftermarket bumper will never fit like an OEM.
Old Nov 7, 2004 | 04:02 PM
BadEH2's Avatar
Default Re: Front Oem bumper Ebay? (yoboslayer)
i sanded my whole car down, and sprayed it with primer.. b/c my friends uncle is going to give me a paint job, so he said prep it up, but i took my friends advice on using the low grit paper...wich i should not have, because i really fucked things up..
Old Nov 7, 2004 | 08:39 PM
TRD MA70's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BadEH2 &raquo;</TD></TR><TR><TD CLASS="quote">GOOOD IDEAAA!! lol im such a retard neway, so i can just put a layer of bondo and then after it drys i can just sand it with VERY HIGH grade of sand paper right?? maybe like a 800 ?</TD></TR></TABLE>
no, when you apply "bondo" (body filler), you wait until its MOSTLY dry then you cheese grate it (use a tool in the autobody world known as a cheesegrater, then you do as it sounds, grate the bondo like you would cheese), then use 180 grit. Then after the bondo, you use whats called a glaze coat. It fills in the small imperfections on the bondo. Sand with 180 then you're good to (primer) seal it once it's smooth. Then after the sealer is applied, you applyt he actual primer, then paint, clear, wetsand, buff, polish.
but like said above, unless its just a small about, it's most likely going to crack if any tension gets put on it. It may be easier just to get a new bumper.
Old Nov 7, 2004 | 11:43 PM
MilanoRex's Avatar
i got my bumper from Certifit for 30 bucks, brand new. Fit PERFECT
Old Nov 8, 2004 | 02:11 AM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Just talk to password JDM its probably cheaper and its mAd jDM yO1
sc34dc4
Aug 8, 2010 08:11 PM
psyk0tic808
Acura TSX
Nov 13, 2008 05:41 PM
Greg50Lt
Honda Civic (2006 - 2015)
13
Aug 19, 2007 03:07 PM
0verd0sed_DC
Mar 14, 2007 01:45 AM
GraphiteMW
Oct 15, 2006 03:31 PM
