DA knuckles onto a DC2?
Old Nov 7, 2004 | 08:01 AM
civiceg6's Avatar
Default DA knuckles onto a DC2?
Alright.. I recently traded and found out that the guy put on some Civic brake system. Which I am displeased. I told him about it and he told me it's OE brake system. To me they don't look OE especially when the rear has drums.
Anyways I have 2 set of DA front knuckles and 1 set of DA rear trailing arms. Would these fit onto a DC? I heard something about it fits onto an EG. But I don't know anything about a DC.
Modified by civiceg6 at 9:22 AM 11/7/2004
Old Nov 7, 2004 | 08:05 AM
Muckman's Avatar
Moderator in Chief
Default Re: DA knuckles onto a DC2? (civiceg6)
I think they should fit without a problem.
Old Nov 7, 2004 | 08:35 AM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiceg6 &raquo;</TD></TR><TR><TD CLASS="quote"> heard something about it fits onto an EG. But I don't know anything about a DC.
Modified by civiceg6 at 9:22 AM 11/7/2004</TD></TR></TABLE>
If it fits an EG, you shouldnt have any problems putting it on the DC, the only problem I could possibly think is that when you pull up your e-brake, it will not travel as far
Old Nov 7, 2004 | 08:50 AM
civiceg6's Avatar
Default Re: DA knuckles onto a DC2? (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">If it fits an EG, you shouldnt have any problems putting it on the DC, the only problem I could possibly think is that when you pull up your e-brake, it will not travel as far
So should I get the e-brake lines from the DA as well? Cause i still have that car out there in the driveway.
Old Nov 7, 2004 | 08:59 AM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiceg6 &raquo;</TD></TR><TR><TD CLASS="quote">So should I get the e-brake lines from the DA as well? Cause i still have that car out there in the driveway.</TD></TR></TABLE>
actually you should be safe with utilizing the e-brake cable from your DC. When I did my front/rear disk conversion on my DC, I decided to keep all my old lines and whatnot. Shouldn't be a problem, just swap everything over and replug the lines
Old Nov 7, 2004 | 09:38 AM
civiceg6's Avatar
Alright.. I have been whacking the ball joint on the lower part of the knuckle and front lca meets. So far it won't come loose. The knuckle is not on the car.
Is it better to put it on the car and then whack the crap outta it? Or do I get a bigger hammer like say a 3 lb sledge hammer?
Old Nov 7, 2004 | 10:43 AM
DC2tuner's Avatar
I Think I'm TOO White For This Thread
can you stop avoiding me and give me the tracking number?
Old Nov 7, 2004 | 10:51 AM
civiceg6's Avatar
Default Re: DA knuckles onto a DC2? (gsrpwr2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpwr2004 &raquo;</TD></TR><TR><TD CLASS="quote">can you stop avoiding me and give me the tracking number?</TD></TR></TABLE>
I didn't avoid you.
Old Nov 7, 2004 | 11:12 AM
DC2tuner's Avatar
does the im not work then? i have sent you im's once a day for two weeks with no reply!
Old Nov 7, 2004 | 11:13 AM
DC2tuner's Avatar
gsrpwr2004 (3:31 PM 11/1/2004): just curious if you found the tracking number?
gsrpwr2004 (6:57 PM 11/1/2004):
gsrpwr2004 (7:35 AM 11/3/2004): still no luck?
gsrpwr2004 (7:37 AM 11/6/2004): tracking number?
civiceg6 (8:28 AM 11/6/2004): Hrmmm... can you give me your address I think I got it. I have about 5 papers that has tracking number on it. I fergot which one is it.
gsrpwr2004 (8:31 AM 11/6/2004): redding ca 96001
gsrpwr2004 (5:02 PM 11/6/2004): did you find the tracking number? please tell me as soon as you can!
gsrpwr2004 (11:35 AM 11/7/2004): cant find it still?
gsrpwr2004 (12:07 PM 11/7/2004): sodo you have it then?
gsrpwr2004 (12:11 PM 11/7/2004): please can i please have the number? its almost been two weeks and my car still doesnt have the fender liners!
Old Nov 7, 2004 | 11:14 AM
DC2tuner's Avatar
sweet you just logged off when i sent you an im and posted in your thread!!!! NOT
Old Nov 7, 2004 | 04:12 PM
DC2tuner's Avatar
WHERE ARE YOU?
Old Nov 18, 2004 | 09:14 PM
DC2tuner's Avatar
well i waited the "two days" for the money order and now its been eleven so im pretty sure ill never get my money back. thanks scammer
Old Nov 20, 2004 | 11:37 PM
DC2tuner's Avatar
civiceg6 where are you and wheres my stuff?
Old Nov 21, 2004 | 02:13 PM
DC2tuner's Avatar
SCAMMER civiceg6 STOLE MY MONEY AND WONT REPLY
https://honda-tech.com/zeromodi...74664
Old Nov 21, 2004 | 03:00 PM
nub.96ek's Avatar
My friend and I put dc brakes on an ef [same as da] and his camber was so off it could't be alligned. I assume if u put da on a dc u will have the same problem [just maybe neg camber... not pos] But yes, it will all bolt on though.
Old Nov 21, 2004 | 03:30 PM
Bl6da9's Avatar
the rear disk brakes from the DA will work on your DC, but the fronts of a DA won't the curve on the spindle is diffrent. I know this cause i did the 5 lug conversion on my DA I din't want to just bolt on the DC front cause it trowing my front end geamtrey of. The spindles will bolt on but are not the same.
Old Nov 24, 2004 | 11:08 PM
DC2tuner's Avatar
Default Re: (Bl6da9)
<U>SCAMMER ALERT!<U></U></U>
92db2gs-r
Suspension & Brakes
Feb 8, 2011 10:42 PM
uses0ap
Apr 8, 2009 08:05 PM
ucc crx
Dec 30, 2007 09:02 AM
liquid:cooled
13
Mar 19, 2007 08:49 PM
JDM-EJ1
10
Sep 21, 2005 07:24 AM
