Unpluged O2 sensor but no check light WHY!!
Old Nov 7, 2004 | 02:15 AM
NOSED_CRX_VTEC's Avatar
Default Unpluged O2 sensor but no check light WHY!!
Hi
I'm running obd1 Hondata with boost and a 4 wire o2 sensor.
After the motor blew up on the dyno when doing the last power run, I put my other motor in but now my car drinks fuel bad, tried changing the o2 sensor didn't work then I unpluged the sensor but got no check light.
Could the closed loop be disabled so the ecu don't reed from the o2 sensor.
Thanks to all.
Old Nov 7, 2004 | 09:02 AM
Devine's Avatar
Default Re: Unpluged O2 sensor but no check light WHY!! (NOSED_CRX_VTEC)
yes you are correct, my car is the same way.
Old Nov 7, 2004 | 10:04 AM
u2civic1's Avatar
Default Re: Unpluged O2 sensor but no check light WHY!! (Devine)
yup with hondata u can disable the o2 but u do lose some gas mileage from it
4tika4
Jul 25, 2009 05:23 AM
kytsday
Jun 16, 2008 12:52 AM
dre2day
Feb 27, 2008 07:27 PM
crxdxsir
Apr 11, 2007 05:59 AM
