rims & tires
ok ive got an 87 accord 4dr LXI. whats the biggest rim size i can get away with, i like the look of a thin tire on a large rim... im hopeing to put 2 -17x8 (+12mm, 4.95" backspace) front, and 2 -17x9 (+24mm, 5.95" backspace) rear.
They are 4-lug (4 on 4.25). These wheels will fit the 1979-1993 Ford Mustang, all models except the '86 SVO and the '93 Cobra.
Will they fit???? what size tire would i need to buy...
why would you put larger wheels in the back, your a front wheel drive car, if you want bigger wheels put them in the front if they fit to get more traction, but seeing how you probally have a stock motor, just get 4 wheels that are the same size
i didnt realy pick em like that, im buyin em off ebay... an smaller tires in the back would look weird. so again whats the biggest tires/rims i can fit on my honda???
you can prolly get away with 18's if u really want to hell people put them on civics all the time but why would you want mustang wheels on ur accord thats just retarded
you should do a little more research before buying them. offsets are different from front wheel and rear wheels drive vehicles. so even though lugs are the same clearances may not be. also using two different size rims means you cant rotate tires from front to rear which gives tires a shorter life span. and 17 and 18 inch tires arent cheap. just a couple of things to consider.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACC0RD22 »</TD></TR><TR><TD CLASS="quote">you can prolly get away with 18's if u really want to hell people put them on civics all the time but why would you want mustang wheels on ur accord thats just retarded
*hands flame suit to graffix*
if i had an 87.... 26's would be the minimum... nothing else about that car will set it off, so hell....better go all out
haha
you might need to roll the fenders with 26's tho........
hahayou might need to roll the fenders with 26's tho........
