how to check dizzy power?
Old Nov 6, 2004 | 06:58 PM
tRex99's Avatar
Default how to check dizzy power?
How do i check if the distributor is putting down the spark its suppose to? It doesnt seem like it when i look at the spark. My car wont start and everything checks out even timing. There is even fuel touching the plugs when i try and crank plus spark but no ignition so i dont think im producing the right amount of spark....
Old Nov 6, 2004 | 07:16 PM
BIG RICH's Avatar
Default Re: how to check dizzy power? (tRex99)
you can check your coil resistence with an OHMs meter. If you have a service manual for your car, it should tell you how to test parts in the dizzy. it should be about the same for the b18a
Old Nov 6, 2004 | 08:12 PM
tRex99's Avatar
Default Re: how to check dizzy power? (BIG RICH)
oohhh...i do have a manual for my crx....yea both obd0 so should be close if not it even covers the B16 from the del sol...i'll check that cept i just need an ohms/volt meter that works...but what numbers should i be getting on it?
jeremiah963
Sep 2, 2008 11:29 AM
tyler100
Aug 24, 2008 06:28 AM
94LSmanual
Mar 22, 2008 06:38 PM
ITRICED
Mar 5, 2008 12:15 PM
rdssk8rcs1
Jun 5, 2006 04:13 PM
