HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods.
Old Nov 6, 2004 | 06:26 PM
Outkasted24's Avatar
Default HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods.
OK, Today I did a cleaning out of my engine bay.
It's a '00 Civic Si.
I used a can of Orange GUNK to break up all the dirt then rinsed the entire engine bay out.
I then drove the car from the driveway to the Garage with no problems.
Tonight (6 hours later) After I got done installing a full Suspension setup, Camber Kit, ITR Valve cover, New Iceman Intake, and tire foamed the engine bay down to make it nice and glossy, I tried to start it up and it acted like the battery was dead.
Then My buddy tried it again and it started up first turn, But was Idleing at 3500+ rpm and was sort of choppy.
What the hell could it be?
I also took out my Cruise Control box ( because my cruise cable was half severed)and moved some stock wire harnesses out of the way.
Yes, I pluged everything back in...except the Cruise Control (because it's not there anymore).
Could the Cruise control box not being there be what's causing this bad Idle?
Or could it be tire shine in a sensor/wire harness?
Anyone have a problem like this before.
Please give meany ideas.... so I can run down the list and figure out what is happening.
Thanks in advance
-Jeff
Old Nov 6, 2004 | 06:30 PM
chad's Avatar
Moderator
Default Re: HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods. (Outkasted24)
your vacuum line for the cruise control has not been plugged!
Old Nov 6, 2004 | 06:35 PM
Default Re: HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods. (chad)
The Vacuum line was removed.
It started from the back of the intake manifold and went to a plastic cylinder, Then to the Cruise Control box.
I eliminated all of it and plugged the vacuum hole up on the intake Manifold.
The entire Cruis control system has been taken out.
Maybe the harness for the CC needs to be....bypassed?
I don't know.
Old Nov 6, 2004 | 06:55 PM
chad's Avatar
Moderator
well you have a vacuum leak....period....if it idles at3500 without serging....you have a vacuum leak
Old Nov 6, 2004 | 07:00 PM
the only vacuum I disconnected was on the back of the intake manifold running to the Cruise Control box.
I cut a 2 inch hose and stuck a screw in it to cap off the nub coming off the IM.
Could that be my problem?
Who has disconnected their Cruise Control here?
Old Nov 6, 2004 | 07:04 PM
Filliam H. Muffman's Avatar
are you sure the 'screw' is in there air tight?
Old Nov 6, 2004 | 07:20 PM
Default Re: HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods. (JUN EK9)
Yeah, I don't think air could get past that screw, It's in there pretty tight and also has some caulking holding it snug.
Old Nov 6, 2004 | 07:29 PM
JDMSiGuy17's Avatar
Hey Jeff i just took my cruise control out of my car too. Your harness doesnt need to be bypassed at all, I just tucked mine away. Anyways it does sound like a vaccum leak to me too. Make sure that you find a screw that almost looks too big and screw it all the way into the hose. If you need any other help im me. How is the intake? Send me some pics of your car. Good luck.
Jeff
Old Nov 6, 2004 | 07:59 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods. (JDMSiGuy17)
Yea, its a hose it not plugged, or the only other problem is that your throttle isnt closed all the way (you can check that easily) or you got a CPU problem, and your IACV is open too much.
Old Nov 7, 2004 | 03:34 AM
Default Re: HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods. (Redline96LX)
English?
Old Nov 7, 2004 | 05:04 AM
Frozen E's Avatar
H-T White Ops
go to autozone and buy yourself some of those little rubber caps to plug up that extra hole on the IM. Hell, $.59 or something like that for 3 of 'em.
Old Nov 7, 2004 | 08:02 AM
PodRacerSi's Avatar
Sounds like either a vacuum line is off, or water has made it's way into a plug or somewhere else it shouldn't. Good luck.
Old Nov 7, 2004 | 08:55 AM
jay.dee.em1's Avatar
Default Re: HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods. (PodRacerSi)
when you installed the intake you didnt mess around with the idle screw on the throttle body did you? if so, go back and turn the screw until your idle goes down
Old Nov 7, 2004 | 08:58 AM
slambedcivic's Avatar
Default Re: HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods. (jay.dee.em1)
just get vacuum caps and use those
Old Nov 7, 2004 | 01:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay.dee.em1 &raquo;</TD></TR><TR><TD CLASS="quote">when you installed the intake you didnt mess around with the idle screw on the throttle body did you? if so, go back and turn the screw until your idle goes down</TD></TR></TABLE>
Nope, Still at stock setting.
I have an idea what it is but I've been down with a bad Migrain headache today.
I'll look into the problem a little deeper tomorrow, But I'm thinking that the throttle cable for the Cruise Control box is tied up and may have tension on the gas pedal, that may be the reason for the 3500+ RPM.
I'll keep you all posted as soon as I'm back on my feet.
Peace
Old Nov 7, 2004 | 02:02 PM
have you disconnected your battery to reset the ecu? not sure if it will do anything, but its habit for me to do this after any mod
Old Nov 7, 2004 | 02:10 PM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkasted24 &raquo;</TD></TR><TR><TD CLASS="quote">
Peace</TD></TR></TABLE>
That's what came to mind for me as well. Make sure that your throttle cables are not hung and sticking the tb open.
Old Nov 7, 2004 | 03:50 PM
chad's Avatar
Moderator
Default Re: HELP!!!! EM1 Idleing at 3500+ RPM, Just got done doing some mods. (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
That's what came to mind for me as well. Make sure that your throttle cables are not hung and sticking the tb open.</TD></TR></TABLE>
i forgot about that cable....that would be the second thing i checked
erikiksaz1
Jun 22, 2010 02:13 PM
91(si)hatchey
10
Jul 9, 2009 08:43 PM
nikesbdude
Mar 10, 2009 11:56 AM
VADERS_EM2
Oct 25, 2008 05:51 PM
Hella_Fresh
Jan 11, 2006 12:45 PM
