wiring on my 91dx swap help
Old Nov 6, 2004 | 05:35 PM
crow91civic's Avatar
Default wiring on my 91dx swap help
I have a 91 civic dx and I just put my 91 LS motor in i have it mounted and i started to hook up the wires but there is one on each side of the car that dont hook up i have the integra motor harness but the the part that runs into the car i also have the dx harness is there anything i can do to make them work?
Old Nov 6, 2004 | 07:12 PM
BIG RICH's Avatar
Default Re: wiring on my 91dx swap help (crow91civic)
put the DX harness on the motor. its easier to use the DX then it is the integ. I don't remember everything exactly, but I know you need to wire up the extra injectors(maybe all 4, I did), the sensor on the exhaust cam, and extend a few wires(maybe), and flip the two outside wires on the TPS sensor. there maybe more, search around and I'm sure you will find more detailed instructions.
Old Nov 6, 2004 | 08:56 PM
hatchi's Avatar
use your stock harness just convert it
Old Nov 6, 2004 | 09:14 PM
Rywire's Avatar
Default Re: wiring on my 91dx swap help (hatchi)
How to convert http://www.fourthgenhatch.com/mpfi.html
If you dont feel up to it, I can do it for you. Check my sig.
Ryan
Old Nov 7, 2004 | 08:16 AM
Default Re: wiring on my 91dx swap help (droppedcrxsi)
hey ryan is the wiring for a zc the same as a b18 non-vtec?
Old Nov 7, 2004 | 08:51 AM
Rywire's Avatar
no, but very close, the zc has the cps sensors on a seperate solenoid(not on the distributor). Wire it like a si.
Ryan
TweakedTT
Jul 26, 2008 08:07 PM
mikezcdx
Mar 9, 2006 07:16 AM
DarknessInside51
Jun 8, 2004 11:44 AM
manson
Aug 28, 2003 06:26 AM
sydag5
Jul 2, 2002 02:48 PM
