intake manifolds
Old Nov 6, 2004 | 04:48 PM
beat_nut's Avatar
Default intake manifolds
would purchasing a new intake manifold, really make that much difference on an integra with not very many mods. i only got cold air intake, and apexi n1 exhaust.
Old Nov 6, 2004 | 04:59 PM
jdmotorsports's Avatar
Default Re: intake manifolds (beat_nut)
get the blox i.m. its a good investment for the money. it may add only 1 or 2 hp now, but down the line as you do more the results will show.
Old Nov 6, 2004 | 05:09 PM
beat_nut's Avatar
Default Re: intake manifolds (jdmotorsports)
thanks man
Old Nov 6, 2004 | 05:12 PM
no prob. prostreetonline.com has the i.m. for like 200$ onsale. i would grab one while they are so cheap.
Old Nov 6, 2004 | 07:10 PM
eddiedeader's Avatar
Unless you have a vtec engine or planning on putting in cams then it might not be worth it.
Old Nov 6, 2004 | 07:12 PM
dFreezy's Avatar
Default Re: intake manifolds (eddiedeader)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddiedeader &raquo;</TD></TR><TR><TD CLASS="quote">Unless you have a vtec engine or planning on putting in cams then it might not be worth it.</TD></TR></TABLE>
agreed. mild bolt-on setups will not benefit from an IM, it will actually rob power in some areas. do some more research before investing in one.
Old Nov 6, 2004 | 07:26 PM
Default Re: intake manifolds (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">
agreed. mild bolt-on setups will not benefit from an IM, it will actually rob power in some areas. do some more research before investing in one.</TD></TR></TABLE>
actualy a stock engine will see a small increase using a im like the blox. unless you can show evidence it doesnt. i've installed one of these on a 98 integra with i/h/e. it showed a 2 hp increase at around 6krpm. not to mention the throttle response was better.
the IM allows the engine to breathe better. when combined with a intake and bored throttle body, its a great improvement.
Old Nov 6, 2004 | 07:30 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">
placebo effect. im pretty sure he will lose low and midrange if he does the im with only minimal bolt ons. and for 2 hp? you can't even feel that. might as well have saved a little more and bought cams instead, and gotten the mani later. maybe then you'd have actually felt an improvement when you bolt it on.
Old Nov 6, 2004 | 07:42 PM
Default Re: intake manifolds (LSvtec03)
actualy the hp curve never dipped below the pre-im baseline. torque actualy was pretty smooth all the way to redline.
but for 200$ its a good investment.
and even if you put cams into a stock engine your not gonna get a whole lot of increase.
patrickstar
15
Dec 16, 2007 06:36 AM
redteggy98
Apr 11, 2007 07:00 PM
integlspwr2k
17
Oct 11, 2006 10:27 AM
EJ1DOHCVTEC
Jun 18, 2006 01:27 PM
$$broke_db8
Dec 20, 2004 02:32 PM
