Brake kits for the Accords now ready...
I have finished the test fitting of the 11" 2 piece rotors and the 11.75" rotor kit for the 1998-2001 Accord. I can substitute the 12.2" rotor if you are running 16" or bigger wheels.
I'll start taking orders on Jan 2.
11" stock style rotors bolt on using ITR/Accord Wagon calipers, $65 each.
11" 2 piece rotors for the 4 cylinder cars bolt on using the ITR/Accord Wagon calipers, priced at $360/pair.
Here's what the 4 piston kit includes:
2 piece 11.75" rotors, w/aluminum hats, hard anodized black
4 piston Superlite calipers
adapter brackets, etc
brake line adapters
Special introductory price of $675.
Optional parts:
12.2" rotors $50
Billet calipers $200
Slotted rotors $50/pair
Directional vane rotors $50/pair
[Modified by fastbrakes, 8:25 PM 12/23/2001]
[Modified by fastbrakes, 7:03 AM 12/28/2001]
brake line adapters
Optional parts:
12.2" rotors $50
I'm still trying to figure out the kit for the 5G. With the funky hub/rotor combo it will take a separate system...
i have already done an oem upgrade to 11.1" rotors, is there a wilwood 4-piston caliper that i can use instead of the stock ones i upgraded too accord v6/itr calipers TIA
4th gen (90-93) front brakes are identical to the 5th gen as well, so whatever works for the 5g works for the 4g!
Fastbrakes you rule! I've been watching your page for quite some time for an Accord brake upgrade.
OK I'll see if I can figure out the easiest way to make an aluminum rotor hat fit the rotors that are available...
fastbrakes
Jul 10, 2001 05:38 PM
