do Si and dx models need integra hubs when doing b series swap?
Old Nov 6, 2004 | 12:15 PM
MulletManRockStar's Avatar
Default do Si and dx models need integra hubs when doing b series swap?
also can you cut and reweld the stock shift linkage to make it work?
Old Nov 6, 2004 | 12:22 PM
B16 ED9's Avatar
Default Re: do Si and dx models need integra hubs when doing b series swap? (MulletManRockStar)
When I did my B16 swap in my CR-X I kept my si hubs, and it worked fine, So the answer would be no, you don't need integra hubs. I don't think you can cut and reweld the stock shift linkage to make it work, wait what motor is going into the CRX? B16, LS? LS-Vtec?
Old Nov 6, 2004 | 12:29 PM
X-Static's Avatar
no you dont need specifically integra hubs for any model CRX, but for the HF you do have to get Si or DX hubs i believe because theyre too small for the axles..
next thing..you can cut and reweld the shiftlinkage from a b-series tranny to fit your crx chassis..but the d-series linkage will not workwrether you cut it or not the side the bolts to the tranny is different.
Old Nov 6, 2004 | 02:03 PM
JDM97TEG's Avatar
Default Re: do Si and dx models need integra hubs when doing b series swap? (X-Static)
no you don't need to change your hubs. i wouln't recommend cutting and welding the shift linkage though, doesn't seem safe
Old Nov 6, 2004 | 03:17 PM
sickofjdm's Avatar
yes you can cut and weld shift linkage...use a 90-93 teg, mark it and cut it shorter.all of mine are done that way, no problems ever! **** spending 200 bucks for linkage.
Old Nov 6, 2004 | 03:33 PM
deftones0817's Avatar
Default Re: (sickofjdm)
if you got skills reweld the shiftlinkage. dx and si spindles/knuckles will work hfs will not.
Josh
Old Nov 6, 2004 | 04:07 PM
Default Re: (deftones0817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">if you got skills reweld the shiftlinkage. dx and si spindles/knuckles will work hfs will not.
Josh</TD></TR></TABLE>
Thanks guys...yeh I got welding skills...Welded a new frame rails on a EG last month.
bubba3369
Aug 30, 2009 07:14 PM
baked_beanz
Jul 19, 2005 07:17 AM
jake1511
Jun 11, 2005 05:35 AM
thecorey
Sep 26, 2002 02:13 PM
IntegD
Jul 23, 2002 10:01 PM
