Removing hub from 94 accord
Old Nov 6, 2004 | 09:24 AM
bigjam369's Avatar
Default Removing hub from 94 accord
Does anyone know how to remove the hub from a 94 accord or where to find a link that could help me with this?
Old Nov 6, 2004 | 01:46 PM
KatyHonda's Avatar
Default Re: Removing hub from 94 accord (bigjam369)
Do you mean how to remove the hub from the suspension knuckle? Accord manual indicates
1) remove knuckle from vehicle - You have to remove spindle nut, brake caliper, separate tie-rod from knuckle, separate upper and lower ball jts, and separate drive shaft from hub.
2) 4-bolts retain hub to knuckle. The hub may be pressed into the knuckle additionally, as I've read of others having problems separating the two. Honda manual doesn't indicate this is the case however. I did a similar job on rear wheel of BMW and took the entire knuckle to a machine shop to separate hub from knuckle, install new wheel bearing in hub, and re-press hub into knuckle. It was worth every penny of the $35.
I would suggest purchasing a 94 Honda shop manual before tackling this job. You won't regret it. Check ebay for used and helminc.com for new.
good luck
Old Nov 6, 2004 | 02:17 PM
bigjam369's Avatar
Default Re: Removing hub from 94 accord (KatyHonda)
Thank you.
psychojason
May 10, 2011 12:23 AM
chrism2352
Nov 3, 2009 02:58 PM
TEAM JDM-P
Aug 13, 2007 03:36 AM
87 Saleen
Dec 17, 2004 02:57 PM
Scott R
Nov 11, 2004 03:57 PM
