shift kits
I found an article in a website about shift kits a while ago... if it's not the right thing you're looking for, maybe someone else here will know more about it... and whether it's available for your accord, i have no idea... it's always fun to search around..
[Smooth shifting transmissions accomplish smoother shifting by being in two gears at once when shifting up. It's known as shift overlap. Shift kits reduce or eliminate the shift overlap and speed up actuation of the shift, hence the harder feel to the shift. A shift kit will reduce wear because you won't have the trans trying to be in two gears at once.]
