my brakes are acting up no leaking fluid either. need an answer
Old Nov 5, 2004 | 07:30 PM
SkoundrelUSA's Avatar
cute little bastard
Default my brakes are acting up no leaking fluid either. need an answer
94 Civic VX Setup: stock front brakes,rotors, calipers, pads. rear disc conversion off a 94 Si with all stock rotors, calipers, pads. master cylinder and booster off 93 gsr, 40/40 proportion valve, and stainless steel lines around all four corners. Bled the brakes with the order: Right rear, left front, left rear, and right front
Heres the problem: When I'm driving on the highway, and haven't pressed my brakes in a while, then I go to press them, and theres a huge gap in the pedal. After that first tap on the brake pedal, the gap is no longer as big and goes back to normal. I checked the booster and it doesn't seem to leak or have lost any fluid. Could it be my lines being shitty? Bled the brakes incorrectly? Maybe just bad pads? Please help, thanks in advance.
Old Nov 5, 2004 | 07:34 PM
Kamin's Avatar
Default Re: my brakes are acting up no leaking fluid either. need an answer (SkoundrelUSA)
2 things come to mind when i hear this
1) master cylinder, the seal between the sections
2) brake booster, do you ever get a hard pedal?
Old Nov 5, 2004 | 07:46 PM
murtnabila's Avatar
Default Re: my brakes are acting up no leaking fluid either. need an answer (Kamin)
I've had a problem similar to this before. Ended up being bad calipers, I just got a rebuild kit.
Old Nov 5, 2004 | 08:13 PM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">2 things come to mind when i hear this
2) brake booster, do you ever get a hard pedal?</TD></TR></TABLE>
i havent looked into these ill check in the morning
Old Nov 6, 2004 | 06:32 PM
cute little bastard
bump
Old Nov 6, 2004 | 09:32 PM
cute little bastard
ttt
Old Nov 6, 2004 | 09:47 PM
Jowee's Avatar
I personally bleed from right rear, left rear, right front, then left front in all of mine and my friends cars with no problems. Try searching the archives and see what else it could be if that doesn't work.
Old Nov 6, 2004 | 10:10 PM
Del_Slo_1's Avatar
Default Re: my brakes are acting up no leaking fluid either. need an answer (ITR 98 1162)
I work at a goodyear service shop. First of all, you should bleed both fronts, then both rears. Secondly, it sounds like bad calipers. If neither of these are it, go to the master cylinder.
Old Nov 6, 2004 | 10:28 PM
murtnabila's Avatar
Default Re: my brakes are acting up no leaking fluid either. need an answer (Del_Slo_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slo_1 &raquo;</TD></TR><TR><TD CLASS="quote">I work at a goodyear service shop. First of all, you should bleed both fronts, then both rears. Secondly, it sounds like bad calipers. If neither of these are it, go to the master cylinder.
Somebody else care to comment on this? Isn't it furthese from mc to closest? Front then rear don't make sense to me...but then again I don't know everything.
Old Nov 7, 2004 | 05:59 AM
cute little bastard
Default Re: my brakes are acting up no leaking fluid either. need an answer (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila &raquo;</TD></TR><TR><TD CLASS="quote">
Somebody else care to comment on this? Isn't it furthese from mc to closest? Front then rear don't make sense to me...but then again I don't know everything.</TD></TR></TABLE>
yea this is why im confused. everyone says to bleed in different orders.
Old Nov 7, 2004 | 09:12 AM
Del_Slo_1's Avatar
I'm sorry....I posted a bit late last night...plus I was drunk. It's actually rears first than fronts. My bad
Old Nov 7, 2004 | 10:14 PM
eg6T's Avatar
who taught u to bleed both fronts,then the rear? well they are wrong and you shouldnt work at a service shop.you are suppose to bleed the line farthest away from the master cylinder first.which was said above by itr 98- rear right,then rear left,front right,then front left.
easy way to find out whats causing the problem is(car is off)-- clamp off all 4 brake hoses about 2 inches above where it enters the caliper.then try pressing the brakes,if the pedal is firm,the problem is not your master cylinder,if the pedal is soft,it is your master cylinder...after that take one clamp off at a time and test the brakes,each time you take a clamp off,the brake should be hard.if u take a clamp off and the brake gets softer,there lies your problem
if you clamp of all the hoses,and take them off and feel no differenc,move the clamps up on the hose higher,this will check for soft lines
Old Nov 8, 2004 | 04:47 AM
cute little bastard
Default Re: my brakes are acting up no leaking fluid either. need an answer (eg6T)
thanks ill try that
Old Nov 8, 2004 | 09:52 AM
Del_Slo_1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">
if you clamp of all the hoses,and take them off and feel no differenc,move the clamps up on the hose higher,this will check for soft lines</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slo_1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry....I posted a bit late last night...plus I was drunk. It's actually rears first than fronts. My bad </TD></TR></TABLE>
Did you read my last post? Don't talk sh*t. Thank you.
Old Nov 8, 2004 | 04:13 PM
eg6T's Avatar
Did you read my last post? Don't talk sh*t. Thank you. </TD></TR></TABLE>
i actually didnt read your last post,and i really dont want to read anymore of your posts...did u quit the shop yet?
Old Nov 8, 2004 | 06:23 PM
Del_Slo_1's Avatar
You've got serious flame issues pal
Old Nov 8, 2004 | 10:20 PM
eg6T's Avatar
not really
94 IntegraLS
21
Jun 11, 2012 08:41 PM
EJ1_Sleeper
Sep 8, 2009 12:09 PM
daily_driven_accord
Mar 1, 2008 07:55 PM
kurinto
16
May 4, 2005 03:42 PM
DriveSideWays
Aug 7, 2004 05:34 AM
