MSD 6A 6200 Ignition and Blaster2 Coil will this fit my delsol b16a???
Old Nov 5, 2004 | 02:17 PM
one slow eg5's Avatar
Default MSD 6A 6200 Ignition and Blaster2 Coil will this fit my delsol b16a???
http://cgi.ebay.com/ebaymotors...41046
click on link..
thanks
jeff
Old Nov 5, 2004 | 07:58 PM
Default Re: MSD 6A 6200 Ignition and Blaster2 Coil will this fit my delsol b16a??? (one slow eg5)
Old Nov 5, 2004 | 08:16 PM
Average Al's Avatar
the ignition box would work
wires cap wont
u would need to convert ur cap to external coil
and get a new cap
Old Nov 5, 2004 | 08:27 PM
Kamin's Avatar
Default Re: (Average Al)
honda igniton systems are very well designed from the factory, honestly you are wasting your money. a 6AL box isnt gonna gain you much. on a dyno with a supercharged B16 we ganed about 5 midrange but lost in the top end.
Old Nov 5, 2004 | 10:58 PM
Default Re: (Kamin)
hm so it isnt the same as on a mustang? I got lots of qick power. Faster revs, cleaner spark, and better fuel.
So i got the ignition, coil, cap, plugs, and your saying it will not do much?
thanks for you opinion...
jeff
Old Nov 5, 2004 | 11:05 PM
Br1anPham's Avatar
Default Re: (one slow eg5)
You got better fuel from a upgrade ignition system?
Old Nov 5, 2004 | 11:13 PM
DJ_SaNdOz's Avatar
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">honda igniton systems are very well designed from the factory, honestly you are wasting your money. a 6AL box isnt gonna gain you much. on a dyno with a supercharged B16 we ganed about 5 midrange but lost in the top end. </TD></TR></TABLE>
I agree.
Old Nov 6, 2004 | 01:15 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Kamin)
This isn't entirely true. While the ignition systems are pretty solid, it is a well known fact that Honda coils are the weak link in the ignition system. They don't produce a real strong spark and their lifespans aren't that great either. I would consider using an ignition box if I was running boost but if you're NA just swap out your coil for an external one and you'll be fine for a long time.
Because Honda combustion chambers are a lot more efficient than most any domestic V8, a spark enhancing system like MSD will make more of a difference on that motor than a Honda engine.
Old Nov 6, 2004 | 07:41 AM
Kamin's Avatar
Default Re: (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">This isn't entirely true. While the ignition systems are pretty solid, it is a well known fact that Honda coils are the weak link in the ignition system. They don't produce a real strong spark and their lifespans aren't that great either. I would consider using an ignition box if I was running boost but if you're NA just swap out your coil for an external one and you'll be fine for a long time.
Because Honda combustion chambers are a lot more efficient than most any domestic V8, a spark enhancing system like MSD will make more of a difference on that motor than a Honda engine.</TD></TR></TABLE>
you are correct about the coil, but getting an external coil like a blaster is alot cheaper than an entire ignition box.
Old Nov 6, 2004 | 08:09 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Kamin)
you are correct about the coil, but getting an external coil like a blaster is alot cheaper than an entire ignition box. </TD></TR></TABLE>
Yes and that was the whole point I was making
Old Nov 6, 2004 | 11:29 AM
K first off i guess i should of said do people use them at sport compact races, cuz every car has them, so i garrentee it is usefull to have. I just wanted to know if it workd on my engine. It duz just have to get cap and new plugs. Thanks for the advice but im going to be pushing more hp then most.... on the street....
Better spark better pure fuel.... Read on it...
Thanks anyways..
jlfrnce
Nov 8, 2007 03:51 PM
93 ls
Apr 7, 2006 06:02 PM
REDSOL
May 7, 2002 12:39 AM
