What are all the parts necessary for the timing belt/water pump maintenace?
Old Nov 5, 2004 | 12:35 PM
B18Redline's Avatar
Default What are all the parts necessary for the timing belt/water pump maintenace?
What are all the parts necessary for the timing belt/water pump maintenance?
timing belt, water pump,.........
Is there anything else I should get done while I'm doing this? like a cam seal or something...
Old Nov 5, 2004 | 03:42 PM
Copy Cat's Avatar
Default Re: What are all the parts necessary for the timing belt/water pump maintenace? (Redline07)
tensioner is also recommended
Old Nov 5, 2004 | 03:58 PM
Echo7847's Avatar
Default Re: What are all the parts necessary for the timing belt/water pump maintenace? (CivicFerioViRs)
Front seal (oil pump) and cam seals if there is visible leakage.
Old Nov 5, 2004 | 06:10 PM
Medek's Avatar
Default Re: What are all the parts necessary for the timing belt/water pump maintenace? (Echo7847)
belts, pump, cam seals, crank seal, and if nessacery valve cover gasket. do it right the first time.
Old Nov 6, 2004 | 10:26 AM
B18Redline's Avatar
thanks, what belts will I need?
Falloutkid90
Honda Civic (2001 - 2005)
Mar 19, 2024 07:30 AM
jttca
Jun 11, 2011 04:11 AM
the soL that could
Jan 12, 2011 09:40 PM
freezerman
Aug 30, 2007 03:30 AM
idriveadelsol7
Dec 8, 2005 06:00 AM
