clutch problems *noise*
Old Nov 5, 2004 | 11:27 AM
m3dia_lab's Avatar
Default clutch problems *noise*
ok heres my problem, i tried searching and came up with nothing related...
if my clutch is not pressed in there is a rattle or knocking noise comming from the clutch area....
any ideas to what it may be?
Old Nov 5, 2004 | 11:29 AM
smart monkey's Avatar
Default Re: clutch problems *noise* (m3dia_lab)
possibly throw out bearing going bad or mabe a bad disc with a loose spring or maybe even a bad trans bearing. would need to hear in person to know. does the sound go away after you press the clutch?
Old Nov 5, 2004 | 01:00 PM
m3dia_lab's Avatar
yeah you know if you push in the clutch it realease from the flywheel, well when i push the clutch i can still hear it spinning making the noise until the clutch stop spinning....
Old Nov 5, 2004 | 01:05 PM
StrikerX's Avatar
Default Re: (m3dia_lab)
friend of mine had same problem in his nissian. we went to drop the transmission then found some how he damaged his clutch fork. replace the fork with a junkyard part and bought a new clutch set. was good after that. I heard the clutch fork can be damaged by resting your hand on the shifter while the clutch is engaged, same as resting your foot on the clutch.
Old Nov 5, 2004 | 01:12 PM
95excoupe's Avatar
Default Re: (StrikerX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey &raquo;</TD></TR><TR><TD CLASS="quote">possibly throw out bearing going bad or mabe a bad disc with a loose spring or maybe even a bad trans bearing. would need to hear in person to know. does the sound go away after you press the clutch?</TD></TR></TABLE>
Exactly, When I took my last trans apart it was all 3. If it is a clutch spring loose or broken you will mostly hear it when you change gears. The throw out is just a steady noise when the clutch pedal is up, its a metal on metal type sound but not whinny, hard to explain. If its a trans bearing (which are complete **** i might add, if you ever look at one they are plastic in the inside) it will sound like a chugging sound like a train. Try and explain the nosie better and we can help you out. Also a trans from what car? if its a sohc and you have FI get used to changing it out alot.
Old Nov 5, 2004 | 01:29 PM
StrikerX's Avatar
Default Re: (95excoupe)
but good thing the sohc trannies are cheap, compared to the b-series at 500+ and still may have grinding probs.
Old Nov 5, 2004 | 03:59 PM
m3dia_lab's Avatar
its an 94 ex tranny, the clutch has had a throw out bearing problem , the squeek when my foot is not on the clutch....
i noticed it when i was sitting at a stop light with my radio turn off and my car sounded louder than normal...
it kinda sounds like theres something loose inside the tranny/ clutch area....
Old Nov 5, 2004 | 05:34 PM
93_cxEG's Avatar
hey bud i had the same situation too...in this case check your transmission fluid and try flushing it if it doesn't help man u need a new tranny fo show! i blew my tranny that way....i heard the noise from the inside and even when i pop my hood...its is not the bearing from what i think it could be that your tranny is gone bad......
Old Nov 5, 2004 | 06:07 PM
CardDealer's Avatar
Banned
Default Re: (93_cxEG)
Modified by CardDealer at 5:21 PM 11/16/2006
Old Nov 11, 2004 | 05:22 PM
andyhurz20's Avatar
In my brothers race car he heard a clunking noise it turned out that the pressure plate or it might have been something with the one of the springs, but it came apart. He sent it back to centerforce and the remade the part and sent it back to him. Sorry I can't really help any more unless I heard the noise or dropped the transmission.
Old Nov 11, 2004 | 06:25 PM
Jimmy's Avatar
Global Moderator
I had the same symptoms and mine turned out to be the input shaft bearing.
Go to slhondaparts.com for cheap prices.
LandeZak
Sep 9, 2013 10:38 PM
siboii08
Honda Civic (2006 - 2015)
Mar 27, 2008 08:35 AM
jbsmith
Aug 29, 2005 12:21 AM
jdmcivicferio
Jul 9, 2004 02:15 PM
rockwilda
Jun 19, 2002 03:57 PM
