still cant get help with VSS.
Old Nov 5, 2004 | 10:06 AM
FakeJDMEF8's Avatar
Default still cant get help with VSS.
so i have the JDM GSR cluster in and wired...followed all wirings...but the speedometer wont work. everything else does...can anyone help me...does the signal wire or power wire get tapped into the ecu or another wire...still cant figure it out...any info would be GREATLY appreciated...
Old Nov 5, 2004 | 10:56 AM
B16 ED9's Avatar
Default Re: still cant get help with VSS. (FakeJDMEF8)
HAve you checked the tranny where the VSS plugs in to? It might have slipped out, or have you checked back of your gauge cluster where the other end of the VSS connects to that might be loose as well. I had the same problem on mine as well, on my B16, the VSS had come lose from the tranny and the gauge cluster, so my
speedometer wouldn't work and my ECU was giving a code for the VSS. I pluged it back in from both sides my problem was solved. NO ECU codes anymore, and my Speedo works fine now You may wanna check those first
Old Nov 5, 2004 | 11:27 AM
doublethink's Avatar
dude what engine you running?
cable or electronic vss?
If your not running an mechanical vss, then you need to swap it out for a jdm cluster.
On the USDM cars its a mechanical cable that goes to the cluster, and the cluster outputs to the ecu.
For the jdm, the electronic vss outputs to both the ecu and the cluster, and the speedo really only displays the info not puts anything out.
need more info to answer the question.
Old Nov 7, 2004 | 06:48 PM
FakeJDMEF8's Avatar
running a JDM gsr cluster...elctronic vss...
Old Nov 7, 2004 | 07:22 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (FakeJDMEF8)
you have to run the signal wire to B16 on the ecu. yellow/red wire-
and you also have to run it off of i think b6 on the cluster plug. orange wire.
sirEGhatch
Sep 14, 2012 05:50 PM
civichatch2307
Aug 7, 2007 07:06 PM
I LOVE MY EF9
Jan 18, 2004 10:01 PM
QWKPHKR
Dec 24, 2001 04:22 PM
