obd0-obd1 conversion-whats included?
Old Nov 5, 2004 | 10:04 AM
FakeJDMEF8's Avatar
Default obd0-obd1 conversion-whats included?
im going to do the changeover....whats needed for it to operate properly...im not buying crap parts...i have a b16a right now...what ecu, dizzy, im, and so onm do i need...whats best...will be running a b16b IM soon.
Old Nov 5, 2004 | 10:12 AM
Rywire's Avatar
Default Re: obd0-obd1 conversion-whats included? (FakeJDMEF8)
Ecu... I would get a chipped p28, or a p30. The dizzy is from a obd1, take your pick http://www.distributorking.com offers discounts to h-ters. You also need a 4 wire o2, and a jumper if you want to use one.
Ryan
Old Nov 7, 2004 | 06:48 PM
FakeJDMEF8's Avatar
any other info....???
Old Nov 7, 2004 | 06:52 PM
yoursupinehead's Avatar
Default Re: (FakeJDMEF8)
not all dizzys work, i am in the process of trying to find one that does, i have a sohc zc and the dizzy from a 1995 1.5 doesn't line up at all, i'll post up when i figure it out, unless someone already knows and wants to share.
Old Nov 7, 2004 | 06:57 PM
Deetz's Avatar
Crazy Honda Guy
I did the conversion on a couple of my cars. For the 1st gen B16 i used a 2 piece frog harness, a jdm obd1 pr3 and 93 gsr vtec obd1 distributor and injectors. The step of the injectors is optional though. You can continue to use your old non obd injectors and injector harness if you want to save some $$. The last thing need is a 4 wire o2 sensor which will have leads from the conversion harness.
Deetz
hondachris1994
Mar 10, 2009 07:21 AM
lsvtec hf
Engine Management and Tuning
Jan 21, 2009 12:02 PM
1point5CRX
Aug 23, 2005 12:43 PM
aVstAr
Dec 26, 2003 07:41 PM
DOHCarp
Nov 7, 2002 04:35 AM
