ef owners what size rims/tires you got? do they rub?
Old Nov 5, 2004 | 09:56 AM
hatchinprogress's Avatar
Default ef owners what size rims/tires you got? do they rub?
hey everyone i wanted to know how big of rims/tires does everyone have, do they rub? how low is the car? as far as my ef my tires are: 205-50-15 and on the front tires there is no more inside tread left (and its not cuz of camber wear) and i got about a 2.5-3 inch drop. and i would like to know a good size tire that wont get ate up when i turn
Old Nov 5, 2004 | 09:58 AM
Brownjd's Avatar
Default Re: ef owners what size rims/tires you got? do they rub? (hatchinprogress)
stock si wheels 185/60/14, no rub, 2.5 drop, but bad camber wear on inside
Old Nov 5, 2004 | 09:59 AM
crx_88_si's Avatar
16, 205-40R16, no drop, no rub..
Old Nov 5, 2004 | 10:00 AM
EFSiR's Avatar
that's funny. I"m on stock 14" with camber issue as well! BUT, BUT, those are so cheep to replace!
Old Nov 5, 2004 | 10:04 AM
Default Re: ef owners what size rims/tires you got? do they rub? (EFSiR)
good feed back keep it comin..... also my back tires rub when i turn also but im afraid to check those tires but you can hear em when the car turns
Old Nov 5, 2004 | 10:17 AM
Rywire's Avatar
Jason, remember when I had 16's? They were 205/40/16, I am dropped like 1.8, and there was no problems.
Ryan
Old Nov 5, 2004 | 10:38 AM
Brownjd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">that's funny. I"m on stock 14" with camber issue as well! BUT, BUT, those are so cheep to replace!
that's why i like em. but somehow everytime i need tires, like i do now, i'm ****** broke or have to fix other **** first. oh well
Old Nov 5, 2004 | 10:50 AM
HumanResource's Avatar
195/50R15 on some 15X6.5 wheels with 38 offset
No rubbing but a lot on inside wear
Old Nov 5, 2004 | 10:54 AM
TheSilentChamber's Avatar
225's will either rub stuff inside the fender, or stick out alot depending on offset, and will rub top of the fenders depending on how big the rims are. Heh I tried to stick some spare 15" rims I had on mine that had 225/50/15's on them and they rubed everything and the fenders sat on top of them.
Old Nov 5, 2004 | 11:01 AM
fireant's Avatar
Default Re: (TheSilentChamber)
Camber wear can be GREATLY reduced if you get a good alignment that sets your toe to within a hunderedth of 0.
Camber in itself is not such a big issue (in fact front negative camber is desired for hard cornering like in autocross), but it concentrates the bad effects of toe in or out on a smaller area.
Old Nov 5, 2004 | 11:14 AM
loid's Avatar
i had the same problem when i had azenis 205/50/15....i had to raise it up a bit. now i have 195/50/15's lowered 2.5 and no rubbing but a nice camber wear.
Old Nov 5, 2004 | 11:26 AM
efvader's Avatar
Default Re: ef owners what size rims/tires you got? do they rub? (loid)
2.50 drop with 15's and 195/50s no problems with rubbin.
Old Nov 5, 2004 | 11:30 AM
yeah im thinkin if i go 195-50-15 and from what it sounds like i wont have that much of a prob with that size. on the tires i have now i cant even drive right now cuz everyone that see's the inside of the tire say's they will pop soon
erikiksaz1's Avatar
Default Re: ef owners what size rims/tires you got? do they rub? (efvader)
The weird thing is that when i raised my car a bit, it tended to rub a bit more. Kinda odd, i guess my wheel fit inside the fender nicely when it was a tad lower.
Old Nov 5, 2004 | 11:35 AM
ACRProject's Avatar
Default Re: ef owners what size rims/tires you got? do they rub? (erikiksaz1)
195/50/15 on 15x6.6 +40 offset slipstreams. When my car was slammed my tires rubbed againt my fenders. Had to raise it up about half an inch to stop the rubbing.
Old Nov 5, 2004 | 12:28 PM
tommyL's Avatar
wow.... great job on the hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loid &raquo;</TD></TR><TR><TD CLASS="quote">
oh, and 205/50/15x6.5, azeni's on slips, stock height so no rub.
Old Nov 5, 2004 | 02:11 PM
Nic's Avatar
Nic
I was rolling 205/40r17 on mine for a little while no rub with a 2.25 drop
Old Nov 5, 2004 | 03:22 PM
quicksol95's Avatar
Default Re: (stk crx)
i am rolling on
stock si wheels no rubbing at all
but they are stock 90 si wheels
but hey they are stock si wheels
Old Nov 5, 2004 | 03:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stk crx &raquo;</TD></TR><TR><TD CLASS="quote">I was rolling 205/40r17 on mine for a little while no rub with a 2.25 drop</TD></TR></TABLE> wtf right
Old Nov 5, 2004 | 03:44 PM
sicc83's Avatar
Default Re: (hatchinprogress)
I had 195/50-15s on 15x6.5" +40s, but they rubbed so I switched to 195/45-15s on 15x7" +40 wheels. I drive it with about a 4" overall drop with no rubbing issues.
Old Nov 5, 2004 | 04:00 PM
Default Re: (sicc83)
4" that's low
Old Nov 5, 2004 | 05:11 PM
FOUR-G's Avatar
i have 205/40/16s, lowered...prolly around 3 inches, and i have no rubbing issues. camber is my friend.
but even when i had what i thought to be some positive camber in rear, i still had no rubbing.
Old Nov 5, 2004 | 05:19 PM
turboZChatch's Avatar
Default Re: (90 87 90)
195/40/14 daily 2 inch drop no rub or camber
BY THE WAY I love that black hatch makes me miss mine ALOT but whatever I got a black rex now
Old Nov 5, 2004 | 05:30 PM
japrex's Avatar
yeah that black ef is sex candy.
Old Nov 5, 2004 | 05:39 PM
jisu009's Avatar
Default Re: (japrex)
205/50/15 on 15x7" wheels with +40 offset. Lowered probably 2.5-3" all the way around.
I had to roll the rears. They were rubbing bad even with the 600lb springs I run back there.
