Door Open Beeps
Old Nov 5, 2004 | 09:37 AM
zumiez007's Avatar
Default Door Open Beeps
Alright, when the key is in the ignition and the door is open, the door beeps, to let you know it is open. I know you can turn the key farther to ingition, but I don't want to do that, it drains the battery faster. I also know that you can fix the door pins so that the car thinks that the door is closed. Don't want to do that erithor, cause it will disable the door open sensor for my alarm. Is there any way to disable the beeping make it stop? I've tried looking around under the dash, but haven't been able to find anything. Thanks.
Old Nov 5, 2004 | 12:35 PM
KatyHonda's Avatar
Default Re: Door Open Beeps (zumiez007)
Why not pull the key out of the ignition?
It seems like I got mine to stop by pulling the key almost all the way out of the ignition. I usually just pull the key and drop on the console.
good luck
Old Nov 5, 2004 | 01:31 PM
zumiez007's Avatar
Default Re: Door Open Beeps (KatyHonda)
Because I want to be able to run my stereo. Our school has massive tailgate parties before football games, and some music would be nice. But having that constant beeping is very anoying. And I don't want to turn the key all the way to ACC, because it runs more things such as heat, ac, ect. (i know you can trun it off, but air gets pumped through even when the fans are on off) I just want to stop the beeping.
Old Nov 5, 2004 | 01:47 PM
Morthren's Avatar
if you take off the lower cover under the steering wheel, you will find a 2 or 3 pin connector (seperate from the ignition switch connector that has about 8 wires) it goes to the 'key in beeper'... just unplug that and that should stop it. Hope it helps
Old Nov 8, 2004 | 10:06 AM
zumiez007's Avatar
Default Re: Door Open Beeps (Morthren)
any idea of a color i'm looking for? Is there any disadvantage of disconnecting this plug, i mean except for the lack of that glorious morris code.
Old Nov 8, 2004 | 08:45 PM
zumiez007's Avatar
any other solutions?
tomrylands
Honda CR-V & Element
Apr 12, 2018 12:44 PM
frankiecutz
Nov 24, 2015 12:30 AM
square_1
13
Oct 13, 2010 07:11 AM
oes
Dec 9, 2003 06:38 AM
