CRX with GSR + OBD1 Conversion Dizzy Plug Question.
Old Nov 5, 2004 | 04:52 AM
QUiKSR20's Avatar
Default CRX with GSR + OBD1 Conversion Dizzy Plug Question.
I have searched and havent found an answer. I have a 2000 GSR Swap
in my 89 CRX Si now should I repin the dizzy plug so I have the 89 Si wires in the 2000 plug or cut and solder. I was told to repin which i did but the
wires dont fit 100% and feel it would be better to cut and solder..
My question is what did you guys do in the past ? I want this to be reliable
as can be without any loose wires..
Apreciate the help!
Old Nov 5, 2004 | 05:07 AM
CRX_Control's Avatar
Default Re: CRX with GSR + OBD1 Conversion Dizzy Plug Question. (QUiKSR20)
alot of people just cut and solder.
Old Nov 5, 2004 | 06:01 AM
crx_88_si's Avatar
or you can make a dist adapter harness using a obd-0 dist side plug and 2000 gsr harness side dist plug.. no cutting
Old Nov 5, 2004 | 06:23 AM
deftones0817's Avatar
Default Re: (crx_88_si)
thats what we did we made an adapter harness that **** looks good talk to hondaguyef if you need help
DEF
Old Nov 5, 2004 | 06:32 AM
HamiltonRex's Avatar
Default Re: (deftones0817)
I cut and soldered. Since i wanted to sell my old obd0 distributor with the plug (it was a b series one)
Then heatshrink and you will have no problems.
Old Nov 6, 2004 | 09:55 AM
QUiKSR20's Avatar
Default Re: (HamiltonRex)
Thanks Guys Im going to do this. I repinned it but im not 100% happy
with the fitment.
Old Nov 6, 2004 | 10:17 AM
Rywire's Avatar
Default Re: (QUiKSR20)
Are the rubber grommets sticking out? I use needle nose pliers, and push it flush.
Ryan
Old Nov 6, 2004 | 11:32 AM
abnaasefmb's Avatar
Default Re: (droppedcrxsi)
cut and solder when my dizzy went out i went down to the parts store and got a del slow dizzy for 250 it came with ignitor and coil as well as a lifetime warranty. having the right plugs made changing the dizzy like a five min. swap. use shrink wrap on the wires too.
Old Nov 7, 2004 | 06:11 AM
QUiKSR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Are the rubber grommets sticking out? I use needle nose pliers, and push it flush.
Ryan</TD></TR></TABLE>
The CRX Wires had plastic not rubber and didnt fit into the holes on the OBD2 Dizzy Plug.. Im just gonna cut and solder it up.
Old Nov 7, 2004 | 08:55 AM
Rywire's Avatar
IC, oh ya, the obd2 plug has the "all in one" thing
Ryan
Old Nov 7, 2004 | 11:25 AM
QUiKSR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">IC, oh ya, the obd2 plug has the "all in one" thing
Yep.. No biggie i didnt ruin anything. Ill just cut and solder I just want a
Solid Connection..
DanielP
Jan 18, 2018 11:49 PM
mahatma
Jun 9, 2006 04:14 AM
string
Aug 26, 2005 10:29 PM
turbotime.
May 13, 2003 10:20 AM
turbo sol
Apr 28, 2003 11:08 AM
