header wrap
Old Nov 5, 2004 | 03:51 AM
PiNkSoL's Avatar
Default header wrap
does anyone no if the header wrap works??? Also how much does a throw out beiring cost???
Old Nov 5, 2004 | 04:01 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: header wrap (PiNkSoL)
yes header wrap works. anything to lower the underhood temperature is a good thing.
from san leanardo its like 40 bucks for the t-o bearing.
http://www.slhondaparts.com/br...LEASE
Old Nov 5, 2004 | 04:51 AM
PiNkSoL's Avatar
Default Re: header wrap (boostedcivicsir)
IS THAT WITH INSTALLATION...AND IS IT HARD TO DO??
Old Nov 5, 2004 | 05:01 AM
Mr. Badwrench
a release bearing? you have to remove the trans, and then take out the throw out fork and replace it then reinstall the trans. probably looking 300-400 for a shop to do it.
Old Nov 5, 2004 | 12:23 PM
vulgar_si's Avatar
I've heard that the header wrap can mess up the header, any truth to that?
Old Nov 5, 2004 | 12:58 PM
Padawan's Avatar
Darth ModerVader
Default Re: header wrap (vulgar_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vulgar_si &raquo;</TD></TR><TR><TD CLASS="quote">I've heard that the header wrap can mess up the header, any truth to that?</TD></TR></TABLE>
Yes, for a couple of reasons. I'd personally never wrap a header that was expensive or that I wanted to last. I'd recommend having the header professionally coated (inside and out) if you want to reduce under-hood temps and preserve/protect the header.
Old Nov 5, 2004 | 01:01 PM
StrikerX's Avatar
read a post that by wrapping the header you can crack it. I personally wouldn't since they cost $300 for some aftermarket ones.
Old Nov 5, 2004 | 01:02 PM
EJ1 wilcox's Avatar
Default Re: header wrap (Padawan)
Header wrap will mess up some headers because they keep in the heat and cause more stress than the header was designed for...
I wouldn't use headerwrap on a nice header, but on a cheapo I would...
I am using it on my DIY downpipe and dumptube so people can't see the shitty welds! haha...
itr1244
Welding / Fabrication
Sep 4, 2006 09:04 PM
608 Gangsta
12
Apr 2, 2006 11:09 PM
da'ee
Feb 14, 2005 01:03 PM
S@nt0s
Apr 25, 2004 05:28 AM
