91-crx-si. Beeps won't shut up.
Old Nov 5, 2004 | 01:41 AM
st1100y2k's Avatar
Default 91-crx-si. Beeps won't shut up.
I am having problems with my ignition switch. Occasionally the "key left in switch" warning
beep will go off and not shut up. Sometimes not. Do I need to replace the ignition switch or
clean the connectors...or maybe just disconnect the beeper "if I could fine it"?
thanks for your help in advance.
91-crx-si stock
190,000miles and still ticking.
Old Nov 5, 2004 | 02:02 AM
jc836's Avatar
Default Re: 91-crx-si. Beeps won't shut up. (st1100y2k)
If memory serves me the actual beeper is part of a box mounted on the back of the dash fuse panel. I suspect that the contacts for the switch are shot. The only part that you need to replace is the switch NOT the lock cylinder. If you buy it from the dealer it will cost well over $45. NAPA has them for some cars and it will be a direct replacement.
Old Nov 5, 2004 | 04:26 AM
mr_valentino20032000's Avatar
Default Re: 91-crx-si. Beeps won't shut up. (jc836)
lmao my current beater does that...out of no where the blinkers will stop working, the gas will drop to empty and the "door ajar" ding will start going freakin nuts. I have to punch and beat up the dash and driverside door to get it to stop
80sDweeb
Jan 17, 2014 11:13 AM
EsotericImage
Oct 21, 2013 01:29 PM
Civic Racer X 7
Feb 25, 2011 12:31 PM
jaypain
Nov 30, 2009 10:13 PM
Mike"IAMSLOW"Myers
Aug 8, 2007 01:30 AM
