87 crx si with a stuck pgm-fi light and an eratic idle
Old Nov 5, 2004 | 12:51 AM
syclonecrx's Avatar
Default 87 crx si with a stuck pgm-fi light and an eratic idle
i need help i just bought an 87 crx si and while i was diving it home the pgm-fi light comes on and the engine revs to 3000 rpm and then drops to an almost stall and repeats the same thing all over again when I'm at an idle need some help with finding out what it could be any help would be a big help thanks
Old Nov 5, 2004 | 02:04 AM
jc836's Avatar
Default Re: 87 crx si with a stuck pgm-fi light and an eratic idle (syclonecrx)
Check the vacuum lines. Make sure that none are cracked and that any rubber plugs are tight on the manifold. Also make sure the PCV is working properly. Good luck
2ndgenaccord
Classic Hondas
Jan 20, 2013 12:57 PM
macdaddyman58
Jun 6, 2007 11:03 PM
redrexracer
Dec 22, 2006 08:38 AM
Kooner450r
Dec 27, 2004 09:33 AM
