Extracting An ECU Pin
Old Nov 4, 2004 | 09:45 PM
som3on3_10's Avatar
Default Extracting An ECU Pin
OK, first off here is the link: http://www.hondaswap.com/forum...41608. First off, I just want to say that is a great how-to post. Props to the author. The only problem is, I'm stuck on how to extract the ECU pin. I know that the article states to use a small screw driver and wiggle both sides while pulling out the pin. I've been wiggling that darn thing for hours now and it's not moving. Is there a tool out there that would make this easier? I dunno what I'm doing wrong, but no matter what direction I stick the screw driver into the female side of the ECU plug, the damn pin won't move. If there is anyone who has done this before, please give me your inputs. For I am STUCK!
Old Nov 5, 2004 | 01:04 AM
nub.96ek's Avatar
Default Re: Extracting An ECU Pin (som3on3_10)
I've allways pulled my pins with a needle... but you can buy a tool from a honda dealership for pretty cheap. The tool works well and stopps you from piercing your finger.
Old Nov 5, 2004 | 01:26 AM
DJ_SaNdOz's Avatar
Default Re: Extracting An ECU Pin (NUB-96EK)
I've always used a pointed punch/screw driver thing (like my techie description) or paperclips. There are little rubber grommets that hold them in place. There is a specific spot that you can push on the pin to make it come out easy. I would show you if you were local, I've had to do this TONS of times. The first few times are a PITA, but after that it gets easy.
Luke G.
Sep 6, 2009 06:49 AM
louevilhatch
May 10, 2007 10:13 PM
Soon 2BE
Oct 28, 2006 01:26 PM
EG civic
Jun 16, 2006 08:22 PM
Toda Party
Oct 9, 2001 10:56 PM
