Valve Cover Modifying / Sandblasting
Old Nov 4, 2004 | 09:34 PM
HobbesGSR's Avatar
Default Valve Cover Modifying / Sandblasting
Has anyone attempted to sandblast / beadblast their OEM valve covers? (Mine is a GSR) Any comments on the outcome?
I know i can send my VC out to Airborn and they'll strip and coat it in whatever color i like, but i think i'd rather just take it down to aluminum and then leave it / polish it. Has anyone done this? Polishing or Chrome Plating?
Old Nov 4, 2004 | 09:36 PM
BoostedJeff's Avatar
Default Re: Valve Cover Modifying / Sandblasting (HobbesGSR)
I know plenty of people that have polished valve covers. A little bit too bling for me, but good for show
plusONE jboy's Avatar
why dont you just get a can of aircraft stripper and spray off the paint?
Old Nov 4, 2004 | 09:55 PM
Default Re: (j boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j boy &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just get a can of aircraft stripper and spray off the paint? </TD></TR></TABLE>
this stuff works like a charm, just dont get it on your skin, it burns
Old Nov 4, 2004 | 09:58 PM
stormy's Avatar
Default Re: (JDMHatch4Me)
bling!
Old Nov 4, 2004 | 10:46 PM
@ries's Avatar
yea DIY... pretty easy and fun!
Old Nov 4, 2004 | 10:49 PM
EK-Chris's Avatar
Default Re: Valve Cover Modifying / Sandblasting (@ries)
I sand blasted a valve cover I had. Only to discover the H logo on the bottom wasnt level. I was going to have it poweder coated, but was worried about hitting the letters with a wire wheel, missing and getting the paint. Bead blasting is def the way top go
Old Nov 4, 2004 | 10:56 PM
5STAR3's Avatar
Default Re: (j boy)
Old Nov 5, 2004 | 11:33 AM
HobbesGSR's Avatar
Default Re: (envision2teg)
Hmm... sounds like fun... I'll at least try it before spending $70 to get it colored. - Here's another question, after taking the paint off, what paint should i use to color it? Most likely that DuPont paint that people use to paint wheels right? -Anyone try this? - I think i'll try to paint it first, and if it doesn't work i'll get it "bling-ified"
Old Nov 5, 2004 | 11:37 AM
5STAR3's Avatar
Default Re: (HobbesGSR)
depends on what finish you want.
Old Nov 5, 2004 | 11:38 AM
HobbesGSR's Avatar
A plain, flat finish (not powdercoated) - Maybe dark blue
Old Nov 5, 2004 | 12:10 PM
DnB TeK's Avatar
here my sand blast job.....
Sand Blast
during the process
halfway through
final outcome
Old Nov 5, 2004 | 12:14 PM
RuthlessEF-9's Avatar
JASCO is all i got to say peoples
Old Nov 5, 2004 | 01:46 PM
spoonugn98's Avatar
Just take aircraft stripper and spray on ther so easy and then spary off with water after that you can primer,sealer,paint,and clear I do this **** all the time it works and holds up well. "DUPONT"
Old Nov 5, 2004 | 01:47 PM
DagYo!'s Avatar
i sandblasted mine and shaved the letters
it turned out nice
Old Nov 5, 2004 | 02:10 PM
Pythagoras's Avatar
My friend sandblasted his ls valvecover and used a parts cleaner to get the whole thing nice and clean. Then I believed he just spray painted it and added some sealer or something. He then used a perma marker to color the honda sign. It actually came out looking extremely good. I'll see if I can get some pics
Old Nov 5, 2004 | 03:26 PM
Bart-EK's Avatar
if you sandblast make sure you clean it out... I have one here that was sandblasted and there's sand left over in every possible place... on the friggin inside... I can't see everything on the inside because of the plate that's mounted in there, so I never used it...
so if you're DIY-in it... get some decent paint stripper and do it the easy way...
R.and.Y
Paint and Body
34
Jun 14, 2007 07:25 PM
FhCRubarb
Jan 10, 2007 02:43 PM
DFW
Aug 29, 2005 11:16 PM
bartek_b
Jul 5, 2003 02:19 PM
Dancing is Forbidden
11
Jun 24, 2003 05:43 AM
