Adjusting tire pressures for cold ambient temps
Out of curiousity, how much do you all adjust your cold pressures up for cold ambient temps? How much compensation is too much? I usually don't add more than about one or two pounds maximum if it is really cold out. However, I have heard some people argue that you should actually *decrease* cold pressures when it's very cold out. I'm guesing the reason is that on a cold track you slide more, and the tire generates more heat than usual, which obviously increases the pressures more. Any thoughts?
Cold air is denser than warm air. So I would imagine that cold air acts as a stiffer spring than hot air. This means a cold tire will flex less and take longer to come up to temp if you leave your cold pressures the same as when its warm out.
I want my tire tread to be as hot as possible without getting greasy. To accomplish that I lower cold pressures when its cold so that the tire is squirmier (look ma, a new word :-) when I start out. This causes the tread to flex more which in turn raises the temp more quickly. And, since the operating temp relative to the cold temp is a larger change when its cold out than warm, I can expect my warm pressures to see a greater increase than when running in the summer.
So my answer is lower cold pressures when its cold.
alscrx
10
Jan 3, 2008 06:57 PM
