trouble with the speedo cable...
Old Nov 4, 2004 | 05:06 PM
jdm_lover's Avatar
Default trouble with the speedo cable...
i got the speed cable and all...its just that...the tranny plug that the speed cable is going into doesnt spin so my speedo still doesnt work...just wondering why it aint spinning...
any 90-93 integra guys have this problem when they did a b16 tranny swap to theyre lsmotor think you guys have the solution...?
thanks
Old Nov 4, 2004 | 07:05 PM
HONDA_TYPE_R's Avatar
Default Re: trouble with the speedo cable... (jdm_lover)
Are you saying that the VSS isn't spinning (where the cable plugs into). I have a b16 swap with an S1 tranny, and I have to twist my cable back and forth a few times before it goes in all the way. What type of tranny are you running?
Old Nov 4, 2004 | 11:35 PM
jdm_lover's Avatar
Default Re: trouble with the speedo cable... (HONDA_TYPE_R)
im running a jdm b16 tranny...(jdm) mainly i did put it in all the way....i have no idea why its not working...i mean...i messed with t he cluster and it seems like the cable just needs to spin from the tranny to read the speeds and when i pluged it in the tranny...and drove around...just seems like from the tranny its just not spinning...so im stuck....also i have two extra hoses that are from my powersteering...and theirs no plugs for them on the tranny so i dont know if it runs from the power steering or wat....but its not spinnin...im stuck....
Old Nov 5, 2004 | 12:22 AM
E_Racer's Avatar
well when i replaced my speedo cable too. there was a small clip that makes the speedo cable stick to the tranny. there is a small groove on the speedo cable that has to go into a small groove on the tranny hole too. make sure it goes all the way down and make sure the clip stays tight. i dunno if that helps but make sure the speedo cable is all the way into the hole and the grooves line up.
swint2007
Apr 3, 2010 11:14 AM
LSpimpTEC
Jun 15, 2004 07:38 PM
