SUNROOF QUESTION
Old Nov 4, 2004 | 02:37 PM
ssdjoey1904's Avatar
Default SUNROOF QUESTION
ok so i picked up this 96 integ and it has 1 of those after market sunroofs but it doesnt work and the headliner is beat to **** so i was wondering if i could use the stock sunroof and plug that 1 in instead. and use the headliner from that the sunroof is 1 of those that they install at the dealer so im guessing it should be like tye stock one right? but it you open it from the top not on the dash like the stock any help?
Old Nov 4, 2004 | 03:14 PM
BlueIntegraBoy's Avatar
Default Re: SUNROOF QUESTION (ssdjoey1904)
You won't be able to use an OEM moonroof, unless the moonroof is the same spec as OEM (i.e. glass size, placement, where motors are).
Old Nov 4, 2004 | 03:39 PM
Default Re: SUNROOF QUESTION (BlueIntegraBoy)
**** thats gonna require me doing some work,damn. thanks for the reply anyways hopefully it will work but if it does fit there is there going to be a plug i can plug the stock sunroof into? because like i said this is a aftermarket from the dealer but i open it on the roof near the moonroof it self
Old Nov 4, 2004 | 06:44 PM
Are you asking if you can use the OEM switch? I driven a Civic with an Integra moonroof. He wired everything to an OEM Civic switch.
Old Nov 4, 2004 | 07:00 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssdjoey1904 &raquo;</TD></TR><TR><TD CLASS="quote">**** thats gonna require me doing some work,damn. thanks for the reply anyways hopefully it will work but if it does fit there is there going to be a plug i can plug the stock sunroof into? because like i said this is a aftermarket from the dealer but i open it on the roof near the moonroof it self</TD></TR></TABLE>
im not understanding.
is it an aftermarket moonroof where they had to cut out some of the roof and then they put a pop up style or a cloth style cover on it?
or are you talking about the OEM style where it just slides into the rear end of the roof?
or.. was it an oem at first, then converted into something else? cuz if so.. then you can just see what they did, if they didnt hurt it beyond being fixable, then you might be in business
Old Nov 4, 2004 | 07:42 PM
JustinG60's Avatar
Default Re: SUNROOF QUESTION (..::91TEG-G2::..)
yeh need more info... but if i am getting this right, go to a good fab and have a plug made up of carbon fiber friend of mine was going to have ti done on his turbo corrado, but he sold the car first
Old Nov 4, 2004 | 08:27 PM
Default Re: SUNROOF QUESTION (JustinG60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustinG60 &raquo;</TD></TR><TR><TD CLASS="quote">yeh need more info... but if i am getting this right, go to a good fab and have a plug made up of carbon fiber friend of mine was going to have ti done on his turbo corrado, but he sold the car first</TD></TR></TABLE>
BLING!!!!
TheWhitten
Dec 15, 2015 05:40 PM
Bluebeautycrx91
10
Apr 30, 2014 03:45 PM
Jackie-O
Nov 29, 2008 12:35 PM
lak8
Mar 11, 2004 04:45 PM
Quik89Si
56
Jun 3, 2003 02:38 PM
