i have a bad clutch
Old Nov 4, 2004 | 12:05 PM
Ricen civic's Avatar
Default i have a bad clutch
When i have my car on 4 jack stands only one tire in the front spins i thinks its cause of my bad clutch and the brakes on that side or could it be the tranny all together and my clutch is compelty gone i mean u can bearly move.
Old Nov 4, 2004 | 12:14 PM
prostreetonline's Avatar
Default Re: i have a bad clutch (Ricen civic)
It can spin alone even if you have a brand new clutch. What symptoms is your car showing?
Old Nov 4, 2004 | 12:18 PM
Default Re: i have a bad clutch (prostreetonline)
i dont have any it runs fine expected the part where my clutch is bad and my tires in the front dont wear evenly
Old Nov 4, 2004 | 12:21 PM
Then get a new clutch, and have your car aligned if your tires don't wear evenly. If you don't have many mods, you can just get an OEM replacement (cheap) or a Exedy Organic (little more).
Good luck!
Old Nov 4, 2004 | 12:49 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricen civic &raquo;</TD></TR><TR><TD CLASS="quote">When i have my car on 4 jack stands only one tire in the front spins i thinks its cause of my bad clutch and the brakes on that side or could it be the tranny all together and my clutch is compelty gone i mean u can bearly move. </TD></TR></TABLE>
its because you have an open differental. there is nothing wrong with your clutch, brakes or transmission.
now a bad clutch would be a seperate problem, not related to that
Old Nov 4, 2004 | 12:54 PM
2fast4u831's Avatar
I'm really 2slow
All you have to do is get your car aligned man Your clutch is bad when you step on it and the rpm's go up without the car moving
Old Nov 4, 2004 | 12:57 PM
lohatch's Avatar
if you want both wheels to spin.........get an LSD
patrick4588
May 19, 2008 02:08 PM
_Cyclone_
13
Jan 5, 2005 08:30 PM
DANgerous
Apr 4, 2004 01:37 PM
rody084
Mar 23, 2004 06:00 AM
blufke
Aug 19, 2002 02:07 PM
