DA..... what parts should be replace other than basic tune up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imaginary17 »</TD></TR><TR><TD CLASS="quote">I have a DA at 235k. What parts should be replaced other than the basic tune up parts.
Thanks</TD></TR></TABLE>
Wow, my DA is about to hit 57K original miles body/engine. I feel like a new born child here
I hope I never get to see 235K miles on my baby while I still have it
Im sure new suspension bushings such as Energy would make the car feel tighter. Im sure some struts would help as well. I would also check the engine mounts.
From: That's the wrong tone... I'm Skunk2 certified.
i definitly agree on doing some suspension work. my car has about 235k on it also. here's some of the suspension stuff i've replaced.
-shocks
-springs
-outer tie rods
-most bushings (ES master kit)
-trailing arm bushings
-lower ball joints
i'm still not done. our cars are old. suspension work is unavoidable.
-shocks
-springs
-outer tie rods
-lower ball joints
I've also done upper balljoints in the front. I have 245k on mine. Just start yanking on all the suspension parts to see if anything has play in it. I would avoid the polyurethane bushings. I put them in and they really hurt my ride quality; the suspension was just too stiff for me.
I would do both front wheel bearings if they have not been done yet. You're stuck on the road if they go.
I would check and lube or replace the pins that the calipers ride on. They tend to lose their grease and lock up on you.
Check out http://www.g2ic.com and go to the Teg Tips. There is alot of info on common problems and fixes for our tegs.
http://www.teamintegra.net
May want to change your timing belt if that hasn't been done...maybe the cam seals too.
