Testing Waters: FS: Complete "Poor Man's Type R"
It comes w/
95' USDM GSR Block
JDM ITR Pistons (11:5 Compression)
New bearing and seals
New Gaskets
Fully Balanced and Blueprinted
New ITR Oil Pump
89' JDM B16 Head
Fully P&P
3 angle valve job
Milled 0.030
valve adjustment
ITR Valve Springs
ITR Inner Valve Springs
ITR Valves
1st gen B16 Cams w/ stock cam gears
ITR Intake Manifold
99 SI Throttle Body
STR Fuel Fail
JDM Type Valve Cover
95' USDM GSR Tranny (perfect condition, no grinds)
OEM pressure plate
ACT Street Disc
With this set-up in my EG i was able to run 13.8 in the 1/4 mile. I believe that with some nice cams and tuning, this motor is capable to run low 13's.
I did the compression test and all 4 cylinders are above 220.
Also Included with the sale is OEM Motor Mounts for any 92-95 Civic or 94-01 Teg, GSR Shift Linkage, JDM Vibrant 2.5" Header, GSR Distributor, NGK spark plug wires, basically everting u need to put this motor in a car is included, all you need is a wiring harness, axles, and ecu.
Motor is COMPLETE, WILL NOT SEPERATE!!!!!!
PM ME WITH OFFERS, THANKS
It comes w/
95' USDM GSR Block
New Gaskets
New ITR Oil Pump
89' JDM B16 Head
Fully P&P
3 angle valve job
Milled 0.030
valve adjustment
ITR Valve Springs
ITR Valves
ITR Intake Manifold
99 SI Throttle Body
STR Fuel Fail
OEM pressure plate
ACT Street Disc
benchmade
Northern California (Sales)
Jul 28, 2009 08:04 PM
00 FBP ItR
Sep 18, 2003 12:22 PM
