Ball bearings.. how do you know its bad?
Old Nov 4, 2004 | 07:41 AM
imaginary17's Avatar
Default Wheel bearings.. how do you know its bad?
How can you tell if the ball bearings are going bad?
Modified by imaginary17 at 5:04 PM 11/4/2004
Old Nov 4, 2004 | 07:45 AM
zilverz's Avatar
Default Re: Ball bearings.. how do you know its bad? (imaginary17)
do you mean wheel bearings ?
Old Nov 4, 2004 | 08:03 AM
yups, thanks for the correction. Wheel bearings
Old Nov 4, 2004 | 08:11 AM
JimBlake's Avatar
The wheel bearings can get loose, then the wheel wobbles. But wobbling wheels can also be caused by loose ball joints.
The wheel bearings can also get tight, then they make grinding or growling noise. But brakes can make grinding noises too.
Either way, you may not know for sure until you take it apart...
Old Nov 4, 2004 | 08:20 AM
cjohnson_2's Avatar
Default Re: Ball bearings.. how do you know its bad? (JimBlake)
one way to check is to jack the front end up and pull on the top and bottom of the tire. if its rocking its probably bad.
Old Nov 4, 2004 | 09:18 AM
be.twenty's Avatar
Mine didn't rock back and fourth... but were still worn pretty bad.
There also was no growling sound but rather a loud humming noise. After a while, it actually became louder than my Greddy Evo exhaust. I just got my front drivers side wheel bearings replaced and it's all good now. I can hear my exhaust after 4 months of humming....
Jamezvtec
Honda Civic (2001 - 2005)
Jun 11, 2009 04:43 PM
roterx7
12
Jul 18, 2006 04:27 PM
ViZ
Feb 11, 2005 07:52 PM
Nice_Dc2r
Aug 21, 2003 01:11 PM
Elkins911
Jun 27, 2003 05:25 PM
