d16a6 w/ obd-1 dist??
Old Nov 4, 2004 | 07:05 AM
crx_88_si's Avatar
Default d16a6 w/ obd-1 dist??
Is there any obd1 dist that fits a a6 head w/o modification? i heard the 92-95 dx dist might? anyone have FACTS ?
Old Nov 4, 2004 | 07:11 AM
dr_latino999's Avatar
Default Re: d16a6 w/ obd-1 dist?? (crx_88_si)
I was wondering myself; bump for answer.
Old Nov 4, 2004 | 07:25 AM
The DX Rex's Avatar
Default Re: d16a6 w/ obd-1 dist?? (dr_latino999)
probably wont work
i know when i put a d16z6 motor in my 89 hatch wit an obd1 dizzy wit an obd0 ecu it wouldnt work.
the obd1 dizzy will work if u have an odb1 ecu
Old Nov 4, 2004 | 07:29 AM
Brownjd's Avatar
i've never heard of any obd-1 that will fit. maybe you could somehow replug a Y8 dizzy somehow and convert it to obd-1?
anyways----bump
Old Nov 4, 2004 | 07:40 AM
crx_88_si's Avatar
lol i know an obd-1 dist cant work w/ an obd-0 ecu.
i plan on doing an obd-1 conversion on my a6. but retaining the a6 block/head
Old Nov 4, 2004 | 07:41 AM
crx_88_si's Avatar
the plan...
d16a6 block/head/IM
obd1 conversion using a p06 w/ uberdata for boost.
Old Nov 4, 2004 | 07:48 AM
Brownjd's Avatar
Default Re: (crx_88_si)
so i guess a boosted mini-me is out of the question, cause that would be an easy solution. just a suggestion
Old Nov 4, 2004 | 07:53 AM
crx_88_si's Avatar
dont want to pull the head off...
anyways.. hybrid section replied..
https://honda-tech.com/zerothread?id=1045116
Old Nov 4, 2004 | 08:16 AM
quicksol95's Avatar
a 92-95 dx dizzy will work
i am running a d16a6 in my 92 dx coupe with my d15 dx dizzy
Old Nov 4, 2004 | 08:57 AM
HumanResource's Avatar
Yes it works
It both bolts in and works with OBD-1 ECU
Old Nov 4, 2004 | 09:27 AM
crx_88_si's Avatar
thats what im lookin for.. an obd-1 dist to match a p06 ecu that bolts properly to an a6 head.. dx/lx/cx dist (92-95) is what i need i guess... ty
Old Nov 4, 2004 | 09:45 AM
4drEF's Avatar
Keyboard Humorist
I'm runnging a Y8 head and, as you may know, it has the same distributor bolt pattern as the Z6.
It's converted to OBD-1 with a P28 ECU.
The distributor is from a DX/CX/LX... etc. The only odd-ball OBD-1 distributor is the one found on the D16Z6. Everything else shares the A6 type of bolt pattern.
Old Nov 4, 2004 | 09:56 AM
crx_88_si's Avatar
Default Re: (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">I'm runnging a Y8 head and, as you may know, it has the same distributor bolt pattern as the Z6.
The distributor is from a DX/CX/LX... etc. The only odd-ball OBD-1 distributor is the one found on the D16Z6. Everything else shares the A6 type of bolt pattern.</TD></TR></TABLE>
i think you might have miss-worded something.... cuz y8 and z6 dont share the same bolt pattern
but you are right, z6 is the odd-ball.
Old Nov 4, 2004 | 11:55 AM
4drEF's Avatar
Keyboard Humorist
You're right.
I meant that the Y8 pattern is the same as the A6... I put Z6 on accident.
good catch!
Old Nov 4, 2004 | 12:03 PM
crxgator's Avatar
Default Re: (4drEF)
yeah im planning on this as well...
D16AA6
Y8 distributor
P06 ecu
all i need is a 4 wire o2 sensor and i believe that will be all?
i have the distributor and ecu already, just need a wiring harness for the ecu, and im gonig to make an adapter harnes for the distributor...
eg6civic1538
Feb 28, 2009 01:03 PM
wfocrx
Sep 13, 2006 06:29 PM
EnSAn
Jun 3, 2006 03:12 PM
DieMaster
Apr 2, 2006 05:09 PM
DOHClessEF-9
12
Apr 21, 2005 06:07 PM
