94 Civic EX oil leak - from distributor shaft or cam seal???
Old Nov 4, 2004 | 05:37 AM
Hurricane's Avatar
Default 94 Civic EX oil leak - from distributor shaft or cam seal???
My 94 EX has recently started leaking oil worse (had leaked a tiny bit in past), it looks as if it is coming from the crevice/joint between the engine head and the distributor body.
Has anyone else ever had this problem, if so what do I need to fix it?
Thanx.
Old Nov 4, 2004 | 05:50 AM
93CivicSI's Avatar
Default Re: 94 Civic EX oil leak - from distributor shaft or cam seal??? (Hurricane)
I did, about 5 years ago, I have a 93 Si.
You need #6 on this page, http://www.hondaautomotivepart...EC%29 probably cheaper to go to your local dealer if you consider shipping as well
s3thy97
Jan 23, 2015 12:42 PM
tvanderpan93
Aug 21, 2012 11:52 AM
MumBleZ_94gsR
Aug 4, 2009 11:50 AM
3WheelGTi
Dec 4, 2003 09:06 PM
krshultz
Feb 9, 2002 04:21 PM
