92 YS1 splines diffrent then S1?
Old Nov 4, 2004 | 03:58 AM
sircrxracer's Avatar
Default 92 YS1 splines diffrent then S1?
Just wondering if I need to buy antother clutch if I buy this mint 92 YS1 tranny I have the JDM J1 same as the S1 or 90 Integra. TIA Rob
Old Nov 4, 2004 | 04:41 AM
CRX T-Si's Avatar
Default Re: 92 YS1 splines diffrent then S1? (sircrxracer)
Yes you will need to get another clutch disc.
90-91 = small spline
92-up = big spline
To reduce the confusion with clutches when ordering just say it's for a 94 teg.
Old Nov 4, 2004 | 08:19 AM
Default Re: 92 YS1 splines diffrent then S1? (CRX T-Si)
Ok I thought so........ what about axles do I need to get 92+??? Rob
Old Nov 4, 2004 | 08:36 AM
Eggman's Avatar
axles, pressure plate, t/o bearing, flywheel,... are the same. just 90-91 has a different clutch disc. that is all.
Old Nov 4, 2004 | 09:04 AM
Default Re: 92 YS1 splines diffrent then S1? (Eggman)
Sweet man Thanks Rob
DA is best
Transmission & Drivetrain
Dec 30, 2010 11:10 AM
Hoosier Daddy
Dec 1, 2003 09:50 AM
VTECVillain
Jun 1, 2003 06:53 AM
B20zvtecek
Sep 7, 2002 11:40 AM
