stutter at steady speed
Old Nov 4, 2004 | 01:16 AM
greentahitianlshatch's Avatar
Default stutter at steady speed
alright i have a 91 hatch with a 90 ls swap.....when accelerating at more than prolly half peddal everything is good, nice strong acc. but if you try to maintaine a constant speed at any speed it stutters. my original thoughts are fuel, because i have the hatch fuel pump still i figured it didnt have enough pressure. but the other day i was reading through an old honda tunning and i saw a question about this exact problem.....honda tunnings response was that this is a common problem with a b16 swap, and the problem is the 2 o2 sensors are wired up backwards and they just need switched...they said this happens because you computer dont take o2 readings passed a certain rpm but once you stay at a constant speed it reads these sensors and they are backwards....... also for the newbie part i though my ls only had one o2 sensor? (didnt wire her myself)
gtlshatch
Old Nov 4, 2004 | 01:32 AM
Default Re: stutter at steady speed (greentahitianlshatch)
alright i did things a little backwards.....i just searched and found out this info for a b16 but i didnt find anything for the ls
Old Nov 4, 2004 | 05:26 AM
crx_88_si's Avatar
do a basic tune-up (plugs/wires/cap/rotor, filters etc) and check TPS voltage AND throttle cable tension.
Jdmdelsolb16a
Engine Management and Tuning
May 23, 2011 07:45 AM
slo_hatch
10
Oct 21, 2008 09:49 PM
blackcomet
Dec 3, 2004 11:05 AM
