Computer hook up
How do I connect to the computer on the CRX w/b16. I always thought that it was right under the dash on the drivers side, but i looked and couldnt find it. Help please, I gotta pass emsions and my check engine light is on.
thanx
thanx
You can't connect anything to it, you have to short a 2 pin connector under the dash and watch the check engine light flash and count for the code. Look behind the kick panel.
Lift up the carpet under the dash on the <FONT COLOR="red">passenger side</FONT> and count the flashes on the ecu. You don't need to connect to your ecu unless you're obd 1.
davelarue
Jul 29, 2008 10:45 PM
