Here is my set up...are 12's possible??
Old Nov 3, 2004 | 05:12 PM
PYITR821's Avatar
Default Here is my set up...are 12's possible??
I have 98 civic hatch back with a 99 B18C1...the mods include:
-ACT clutch
-Toda flywheel
-Brand new ITR head (complete with lost motion assemblies, rockers, and cams)
-ITR Intake Manifold
-Mugen head gasket
-Jdm Itr pistons (std)
-Toda cam gears
-ITR AEM CAI
-BFG Drag Radials (205/50/15)
-DC Jdm Header
-2.5" Custom cat-back exhaust
-P28 Ecu with skunk2 program
-no power steering
I know I need some cams and a valve train upgrade....but besides that what else can I do to reach the 12 sec mark? Would it be worth it for me to upgrade my pistons to CTR pistons or should I stick with the Jdm ITR's?
thanks.
Old Nov 3, 2004 | 05:30 PM
hotrex's Avatar
Default Re: Here is my set up...are 12's possible?? (PYITR821)
i dunno if thatll do it. will be in the 13s with good traction though
Old Nov 3, 2004 | 05:35 PM
nyce1's Avatar
I think 13's are surely possible. However, 12's may require some serious weight reduction along with going into the motor for some internal work.
Old Nov 3, 2004 | 06:51 PM
PYITR821's Avatar
Default Re: (nyce1)
would ctr pistons and jun3 cams get me there?
Old Nov 3, 2004 | 06:56 PM
slambedcivic's Avatar
Default Re: (PYITR821)
definately a 13.7s car.... 12s wont be very easy without more internal work... shot of juice might cure your 12s urge
Old Nov 3, 2004 | 09:10 PM
PYITR821's Avatar
Default Re: (slambedcivic)
13.7 doesn't seem right....my 01 ITR did 13.9 with intake, header, exhaust, p28 ecu and a pair of BFG drag radials.
Old Nov 3, 2004 | 10:15 PM
hotrex's Avatar
12s are harder than you think
Old Nov 3, 2004 | 10:23 PM
MassScene's Avatar
Default Re: (hotrex)
your almost there. big cams/ gears adjusted. and some goooooooood tuning on the dyno and your definatly a low 13 maybe 12's on slicks. I went 13.7 w/ stock cams, stock pistons in a ls/vtec on bfg's in a 92 vx hatch. w/ carpet and rear seats removed... its mos definatly possible My goal is to get into the 12's w/skunk2stage2's and ctr pistons w/ good tuning. and i know its possible
Old Nov 4, 2004 | 03:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PYITR821 &raquo;</TD></TR><TR><TD CLASS="quote">13.7 doesn't seem right....my 01 ITR did 13.9 with intake, header, exhaust, p28 ecu and a pair of BFG drag radials.</TD></TR></TABLE>
and this also isnt your ITR
Old Nov 4, 2004 | 07:38 AM
hondaguyef's Avatar
We have a similar setup in an 89' HF minus the ITR pistons. It runs 13.70's @ 98mph. w/ 2.0 60' times. 12's are definately harder to get than you would expect (all motor that is )
Phil
Old Nov 4, 2004 | 08:33 AM
Default Re: (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">We have a similar setup in an 89' HF minus the ITR pistons. It runs 13.70's @ 98mph. w/ 2.0 60' times. 12's are definately harder to get than you would expect (all motor that is )
Phil</TD></TR></TABLE>
ive seen this setup as well... rather impressive if you ask me
Old Nov 4, 2004 | 09:11 AM
Griffin@Camtech's Avatar
Your going to need more then that for 12s.
Also I would not use CTR pistons and jun 3 cams. the jun 3s like lots of compression. look at a set of 12.5 to 1 compression endyne rollerwaves. do the pistons, cams, and some headwork and you will be into the 12s with good traction and driving.
Old Nov 10, 2004 | 04:26 AM
93H22ACX's Avatar
Default Re: Here is my set up...are 12's possible?? (Stickdeath)
its dependant on your hp and driving skills. i would say it'll be low 13's....a local guy with an EG Type R runs 13.3 with 20" slicks...
Old Nov 10, 2004 | 08:27 AM
bluebird's Avatar
Default Re: Here is my set up...are 12's possible?? (93H22ACX)
12's are possible with slicks and some weight reduction!!!
Old Nov 10, 2004 | 08:36 AM
Chuck P's Avatar
Default Re: Here is my set up...are 12's possible?? (bluebird)
Eg 2050 W/driver, 94 B18c1, itr pistons and cams, s2 im, no tune and slicks. 13.1@101 1.760ft. Weight reduction and slicks your there.
Old Nov 10, 2004 | 01:58 PM
deftones0817's Avatar
Default Re: Here is my set up...are 12's possible?? (C Squared Motorsports)
well phil not to jack the thread but once i change the full throttle launch and get my slicks back from you im going to run 12.9s. That is a promise. At least i think its possible with a good tune.
Josh
jdmB18CT-R
18
Oct 29, 2011 09:52 AM
BryanEk
Feb 27, 2005 04:43 PM
Infamous
Apr 30, 2004 04:40 PM
slogsr
14
Dec 7, 2003 08:58 PM
E-spec Tuner
Dec 2, 2003 10:59 PM
